nodust
- 10:34 AM
- Apr 14, 2013
- red deer alberta canada
What Red X?.@nodust
Care to elaborate on your Red X??
What Red X?.@nodust
If I gave someone a red X it was accidental. I have never given anyone a red X and don’t ever plan to. Where is it?What Red X?.
If you NEVER put decent tires on it, you'll probably be fine. Personally, I would never even try to build or drive a 600 hp car without good tires (drag radials on the street, slicks on the track), and good tires require chassis stiffening. I plan on racing my cars, so 500hp up get subframe connectors and a rollbar/cage tied to them.What do you guys think is the max HP that a Charger could handle without frame strengthening? I am hoping to be at around 600 with a small centrifugal supercharger. I do understand that the Hemi's at least had some additional structural support at the front.
There are many strengthening kits and options out there, but I am not sure I need this for a street car that is just going to spin it's wheels anyway.
Also, I am 60+ and my welding skills aren't what they used to be!!!
Unsure, but comments are greatly appreciated!
Also, AZ car, no rust on floor pans. Frame super clean.
in removing some of my old floors & trunk pans I discovered that at least a third of the original welds were broken.What do you guys think is the max HP that a Charger could handle without frame strengthening? I am hoping to be at around 600 with a small centrifugal supercharger. I do understand that the Hemi's at least had some additional structural support at the front.
Looking seriously nice, Dennis. Do all 4 wheels have to be on the ground when those get welded in?USCartool connectors here. Fifteen years and many miles. No damage discovered. Lots of hard miles. Has rigidity more like a modern car. One of the best upgrades ever.
They seem to have the most comprehensive kit. i wish it was bolt in so I could do it myself, but of course it wouldn’t be as rigid then.USCartool connectors here. Fifteen years and many miles. No damage discovered. Lots of hard miles. Has rigidity more like a modern car. One of the best upgrades ever.
Any bolt ins that you would recommend?My 540HP Hemi RR coupe (no subframe ties) would visibly twist when hammered, but not enough to show any cracks; without the Hemi-specific chassis gussets, it likely would have shown cracks. Typically they develop at the cowl & quarter/jamb area, from cars I've seen.
Only ran DOT cheater slicks a couple times; on Radial T/As, yup, it would just buzz them until 3rd gear.
I ran bolt-in ties an a Nova and 2nd-gen Camaro, and although not optimal, they definitely strengthened those cars: I could feel the difference.
If you plan on slicks and really launching the car, I'd definitely add ties at a minimum.
Wow, you did a great job on those!I took 3 x 3 .120 wall tubing and made my own.
Mine were welded to the torsion bar crossmember and to the rear rails.
I made my own torque boxes from 14 gauge sheet metal.
Again, mine are not welded to the floor pan but I did put seam sealer at the edges to fill the gaps.
The car instantly felt more solid. It soaked up bumps and dips like a newer car.
The principle is simple when you look at it this way:
With an unmodified original car, the whole chassis is a series of springs. With a stiff structure, you have a solid platform that allows the suspension to work better. Taking it further, you could say that an original chassis could be compared to a person standing on a surfboard on the water. The water allows the surfboard to move in many directions due to it's buoyancy. Stand on a surfboard on concrete and the buoyancy isn't there. A reinforced chassis is like the surfboard on concrete.
Just a dumb question, but why are you planning on so much horsepower if you don’t plan on having traction as well?Any bolt ins that you would recommend?
I’ll never run slicks on it.
