- 2:53 PM
- Feb 22, 2021
- Roswell, New Mexico
Any progress? Very curious as to
how far you've got this going.
Progress report ? Can I help in anySo glad to hear you've made such progress. Truly a work of art you and your son have created. Well I'd like to report similar progress on my truck, but definitely far from roadworthy at this point. But we'll persevere. As with all of us, life sometimes gets in the way of our projects. Matter of fact I still am interested in the miter box. Tractor hasn't moved an inch since our last correspondence, but the ideas I have for it are, I think, still the way I'm going to go. Just finished some engine work on car I bought to flip. So now it's the tractor's turn to come in the garage for a good lookover. I'll get it in and do some planning, and will definitely let you know if the miter box will work. Thanks so much for keeping me in mind.
Yes, mainly on the drivetrain. Motor and transmission have been rebuilt. Need to finish metal fab on firewall and transmission tunnel. 440'Any progress? Very curious as to
It's a 50/50 primer paint job. If you're half blind and 50 ft away, it doesn't look too bad.
Thanks for the update!1STMP I have the tractor in the garage, and have finalized the plan for the steering. When the weather improves (-30* Celcius here this week) I'll be heading to the local pick-a-part in search of steering linkage from a GM P30 motorhome or commercial van chassis. They use a type of bellcrank system that acts like dual idler arms of a sort. Google these for a look:
SUPERSTEER® SS3032-10D BELL CRANK ARM
SUPERSTEER® P3032 BELL CRANK
As this is just a acreage tractor I won't be needing these to be new, but the pictures should give you the idea of what they are. The bellcrank bracket with arm normally is bolted to the outside of the front frame rail (so 1 needed each side) because of the need to direct the relay rod steering force from ahead of the front axle, through these guys, which will then direct the steering force back to the steering knuckle/arm assembly at the front wheels. I'll mount these on the rectangular metal radiator surround; then I can push the effort back to the tractor knuckle steering arm. A GM Grand Prix steering rack will be used as the steering box/relay rod. It's a bit unorthodox and Kenworth-strong, but that's how I like it. The wonderful thing of this is I can cut steering parts apart and reweld as necessary because it's just a tractor and not a street-legal vehicle. When I can locate these items I'll be set. I'll keep you in the loop on the miter boxes. They will definitely work for me, but don't need them quite yet. And wow your truck looks so good!
I wouldn't even begin to call anyone
The truck looks awesome to me, so I guess I'm half blind (or maybe half dumb too?)!
Only a few times around the block at 25 mph.mainly checking oilWhat a feeling you must have being able to make some laps with it.
Agreed.Post it up, to me it's not all about the brand. It's about the common intrest we share. Hopefully, your son will benefit from it too. 440'
I found another source for the miterbox. Let me know if you may1STMP I have the tractor in the garage, and have finalized the plan for the steering. When the weather improves (-30* Celcius here this week) I'll be heading to the local pick-a-part in search of steering linkage from a GM P30 motorhome or commercial van chassis. They use a type of bellcrank system that acts like dual idler arms of a sort. Google these for a look:
I am absolutely inGreetings All,
The project I've been working on and off
for 26 years is not your typical resto mod.
It's not a B body.
It has morphed into a tribute to my son
who served 9 years of hell in Iraq.
Army Rangers.
He suffers from a traumatic brain
injury and PTSD.
Keeping the garage organized is a major
challenge, as his cognoscenti abilities
are challenged.
Before I start posting pics and history
of the build, I would like to get a consensus
here of who may be interested. in a not
so normal build.
Thanks all....
