Door Fuzzy replacement 2 dr hard top
440 4 speed
6:07 PM
Saskatoon Saskatchewan Canada
Has anyone found an easy way to replace the fuzzies/cat whiskers? These are the outer ones.
Didn’t notice the clips were wrong, so the trim is facing down. This was after the windows were adjusted.
What part is hard? Use a piece of wire to hook the old ones and yank them out and then clip the new ones into place.
Are you talking about the halves that staple to the door panels? My set came with staples so, I drilled holes in the weather strips and installed all the staples in their original positions. Not hard, just time consuming.
These are the outer door ones. Thanks
Thanks. Will take a look, don’t want to scratch the new paint.
Scratch the new paint. Didn't you pull the whiskers before paint?
If not, lower the glass down an extra 1" or so by adjusting the regulator (screw and jam nut) if it's still in. Then you can push the whiskers inward to bend the tabs and they'll pull up easier.
