Sixpactogo
I would pull it back up and move it at least two teeth to the right and try it again. Once you get it right, mark it with a center punch so you don't have to guess again next time.I re-installed the pitman arm today and the steering wheel seems way off from center. The bottom spoke is at somewheer between 4 and 5 o'clock to have the wheels pointing straight. It should be at 6 o'clock. Is this close enough that the wheel can be centered with the tie rod ends or do I have to remove the coupler from the input shaft and re-position it better?
