Cool, looks like fun. Forgot to mentionthank you. snack block will be added to my list. Waiting for some snow to melt.
Ahhhh.....Richard.....You can say snatch. In this context, it’s not vulgar.
That is all.
WOW!!!I get hired to do all kinds of recovery!
Can you knock the pitman arm loose with a pickle fork? Then you could steer the front straight just by hand turning the wheels.I am having trouble retrieving one car. Is there away to bypass the locking steering? I have no key. Can't turn the steering, can't put into neutral to get it on the trailer
I got it done. Now I'm trying to figure out how to get the last Duster home. Driver side torstion bar is broke. That corner is dragging. Wondering how to load it on the trailer.Pull the clip on the shift lever at the trans.
Remove the rag joint or slider box from the steering column.
All easier than the pittman arm or drive shaft.
I have one last Duster to retrieve. Torsion bar on the drivers side is broke, that corner is dragging. Any ideas on how to load this on a trailer??
Good idea. thank youRaise it so the suspension hangs and fill the gap between the lower control arm rubber bumper and frame with a piece of steel or hardwood. How I loaded this Satellite for the same reason. Needing to do this to a couple more cars so I can move them too.
A buddy broke a torsion bar off-roading a Nissan 4x4. Did the same thing you mentioned...jacked, inserted block of wood between lower control arm & bumpstop, ratchet strapped it in place...and (carefully) wheeled it out and then home.Raise it so the suspension hangs and fill the gap between the lower control arm rubber bumper and frame with a piece of steel or hardwood. How I loaded this Satellite for the same reason. Needing to do this to a couple more cars so I can move them too.
