And again, you WILL need a brass tipped FP pushrod IF you are using a billet camshaft. This Howards is regular for a "Cast" Flat tappet camshaft.You could possibly find the correct fuel pump pushrod in the mechanical parts section
Summit Racing description: Fuel Pump Pushrod, Chromoly, SteelTip For Cast Camshafts, .432 in, Dia., 3.22 in. Length, Mopar, Each
For Billet Camshaft:
Howards Cams 92153 Howards Cams Fuel Pump Pushrods | Summit Racing
COMP Cams 4646 COMP Cams Fuel Pump Pushrods | Summit Racing
