INTMD8
DanielG I appreciate it but do not see that happening. Would be glad to assist with any info if you decide to build one like it though
armudster, thank you! My experience so far is only a couple of hundred miles but I think they will be perfect.
I had the same concerns as you and before driving the car actually masked off the inside front fenders and did several layers of catalyzed bedliner as I was concerned about rocks from the tires breaking the paint from inside out.
Also bought some temporary paint film I didn't end up using as they are not throwing a -ton- of rocks like a typical drag tire.
The tires I had on it before were BFG's and they had so little traction with this setup it was rather useless and thought there was a good chance I would put it in a ditch or just not drive it hard.
These seem to be a great balance of traction and still capable of tire spin depending on how it's driven.
That meaning, this engine being higher rpm based, if I go wide open from a lower rpm it hooks rather well and just hazes the tires as it gets to higher rpm.
If I short shift it well, like the video it's just a good rolling burnout.
