- 10:19 PM
- Sep 15, 2009
- State of insanity
Please specify: compact, standard, or large capacity size.What does that equate to in washing machines?![]()
I was thinking standard domestic size - 595mm wide..... something like two foots together (with shoes on if you're a short guy)Please specify: compact, standard, or large capacity size.
That would be three arms lengths. ( Midgets and basketball players excluded ).I was thinking standard domestic size - 595mm wide..... something like two foots together (with shoes on if you're a short guy)
@Geetex help me out here please...![]()
They are infringing on my right to free speech.....I'm height challenged too imo lolAre we allowed to say midgets in today's woke world? Should it be 'height challenged'....
Ok... let me substitute, then... Dwarfs.Are we allowed to say midgets in today's woke world? Should it be 'height challenged'....
I truly do not know the answer to this. A yes and a no could both be possible.
It just seems weird that I was driving the car for over 6 years and didn't notice much wear, then within a few months the tread grooves on the outer and inner edges just faded away.
A tire company engineer should have some insight.
Anyone have contact info for the Michelin Man?
I got the takeoffs from my BIL.....he too used nothing but Mickys and I used them on my flat bed trailer and my Dakota. Not sure if the compound gets harder as time goes on or if they are just losing the cushion effect from the extra tread depth. I've been known to run my tires until they are very elderly but won't run them until the air starts showing. Found out a long time ago that bald tires will hydroplane at around 50-55 depending on how wide they are. And my BIL passed away a couple of months ago so no more takeoffs.A friend of mine that has a truck that uses the same size tires as mine usually gets the tires that I take off. I have always used Michelin tires on that truck up until the latest set. The last set that I removed had about 1/32+ of tread before the wear bars. I had gotten about 48K miles out of them. I find that when they are worn that far the truck rides rougher and the bumps in the road seem harder. Anyway my friend has put these on his truck. The last time I asked, he said they were well into the wear bars and he had about 22K miles on them. So my opinion on that particular brand is that as the tire wears the compound is harder and wears less. In no way can I confirm this on any other brand or type of tire. Those tires had a treadlife warranty of 50K miles and now have a little over 70K on them now. My friend isn't as cautious as me and will drive them until the cord or steel shows.
That sounds very plausible, got new tires on my 3500 Ram, it road very soft till it had maybe 200 miles on them. Now it’s almost like rock feeling.Two things not mentioned. The rubber on new tyres is soft & wears quicker when new. With heat from usage, the rubber hardens & the wear rate reduces. Also, as the tyre wears, the contact area with the road increases, which would reduce the wear rate.
Years ago we were at the Monterrey Historics, a buddies young son saw the guy dresses as the Michelin Man & ran at him full speed... Took out his knees, guy went down hard.... Everyone including him cracked up... Point being does physical contact count???I truly do not know the answer to this. A yes and a no could both be possible.
Years ago we were at the Monterrey Historics, a buddies young son saw the guy dresses as the Michelin Man & ran at him full speed... Took out his knees, guy went down hard.... Everyone including him cracked up... Point being does physical contact count???![]()
