1967 satellite
Here is a pic of the hole in the manifold looking down to the nut. The space between the wall and nut will not take any socket even a thin wall. The hole diameter is approximately .640"
			Yes, the pipes are disconnected and all the nuts have been removed except for the 3 nuts in the hole of the manifold. Pics have been added to the post.So have you disconnected the pipes from the manifolds and have removed all the other manifold to head studs and nuts? Post some pics.
The extended nuts have broken off flush with the stud. You're screwed. And by that I mean looks like you're pulling the motor so you can drill the studs out.
What are extended nuts? Is there a picture and where can I get them?The extended nuts have broken off flush with the stud. You're screwed. And by that I mean looks like you're pulling the motor so you can drill the studs out.
I'd like to be around to see the magic happen.I'd get creative with a length of 4130 tube and a welder... but I like pain.
Yes, you are correct they are nuts. Pics attached. 1967 383-4V. On the right side there are 2, left side 1.You’re not very clear on what you are asking.
Big block?
What year?
Which two?
Factory original there were only studs with nuts. No bolts.
thank you. Now to get them out and replace with the correct one.
 ,thats my kind of luck. Hope it gos well for you.
 ,thats my kind of luck. Hope it gos well for you.not leaking, just wanted to get them ceramic coated.If it isn’t leaking, I’d bolt it back up and save it for another day
That drivers side manifold is off a 70s something or other.not leaking, just wanted to get them ceramic coated.
I was just directly pointing it out in case he wanted something that looked a bit more period correct before dumping his cash into that one.I think he told us that indirectly with it being a 67 383 with "big" manifolds, which were not available that year on that motor.
