Oh I hate starting the Bee when it’s on jackstands. I fear it will vibrate itself off the stands
Had done research about engine temps by reducing (not eliminating) the anti-freeze mix. I’ve run around 30% for the last few years with wetter; though my car is in a heated garage. Straight water isn’t a good idea as it can rust up the engine innards.I love the guys who run straight water in there engines here in the North. I've sold a lot of blocks to them in the spring when they realize they just destroyed their engine for no reason. If you're going to be stupid, you gotta be tough
Doesn't sound crazy at all, When we lived in Anchorage Alaska dad used a 150 watt heat lamp bulb under his 57 Nomad for three years till he finally got a block heater.... It worked in Korea, Adak Alaska and while on his second tour in Germany so it should at least help anywhere...I had that same problem years ago. I put a heating pad (for your back) on each side of the block. Next morning all was thawed out. Sounds crazy but it worked!
Yep, he already ignored that advise that was given earlier. Hopefully the next person won't!Next unfortunate soul that freezes his car may benefit from this advise.
Don't open the peacock or block drains.
It will thaw faster of you leave any water in the system instead of draining it as it thaws. The water transfers heat and it's warmer than the ice.
I'd drain radiator (you still 50% water) want add some anti freeze run engine to circulate anti freeze/water. Then drain system,save that mix for next year. Mark the jugs. If there's an area in egine that doesn't drain and freezes and cracks say a head. I'm a little cautious.Well I learned my lesson, if I’m going to run water then make sure to drain before freezing temps start. Or invest in a garage heater.
Thought he said it leaked last summer?Everyone still seems to be missing that heater core that's gonna be pissin all over the cabin floor next spring!![]()
Thanks Fran! I've been drinkin Rum since I got out of the plow truck, missed that! Would have made it really easy to install that coolant heater I linked for him though ! LOL At least we know why it was leaking last year though....Thought he said it leaked last summer?
Crack one of those beers and see what happens! You'll either have a popsicle or the drink you need right now!
