- 9:46 PM
- Sep 15, 2009
- State of insanity
I recently bought a 69 B that has 440-218 step headers on it going into 3 inch exhaust with X pipe. The starter installed was the TTI recommended Gen 1 RobbMc which is no longer available and last made in around 2010 when they updated to their Gen 2 starter which is 1/2 inch shorter and a bit bigger in diameter than their Gen 1. A lot of modification to the primary tubes and even after that very little clearance between header and starter. Tried all over looking for a starter that would give me more header/starter clearance than the Gen 1 with no success. If you every have to change your starter and/or solenoid it's a real Bit*h of a job. I know TTI are supposed to be the Cadillac, or since this is a Mopar site, the Imperial of headers but before buying a set of TTIs I would check your clearances as you wouldn't want to install your starter only to find out the TTIs won't fit and don't believe for a minute any claims that you can change a mini starter without having to take the TTIs off even on a Roadrunner or Superbird.
A mini-starter can be removed/installed easily with Hooker Comp headers.Every big block header I’ve ever encountered requires the driver side to come off for a starter change…
