Orig69
- 11:41 PM
- May 16, 2021
- Toronto Ontario Canada
A leaking radiator cap can allow air to enter the cooling system.
So you are saying a 160 tstat and 13lb cap would not be better for a hot running motor?You can use a 180 or the 195 which is the original thermostat.
Original rad cap is 16lbs.
2 row rad is original 3 row gets close to the fan blades.
I don’t have access to another carb….but if i keep this car, def will change it to HolleyWhy is a 13lb cap better than a 16lb cap for a overheating engine?
We gain approx 3 degrees of raised boiling point with every pound of pressure. So a 13 lb cap is not as good as a 16 for your hot engine.
I use 160 t stats in some cars and I would use one in your hot machine.
But really consider a different carb. I was shocked and amazed that my overheating car was fixed with a carb swap. Think about it. The entire time the engine was running it was with the wrong air/fuel mix and was building a volcano within the whole time.
Do you have a known good carb on another car, or will a friend loan you one for a few hours so you can test this out and see if it changes.
Bad cap. 180° t stat.Ok guys….. here’s my issue…. Looking for a starting point to remedy.
69 Super Bee, 440, a/t ….
Take car for cruise, at least 30 minutes or more. Checking temp gage, it gets to 200 really fast, but stays there while cruising back roads around 45-50 mph.
Once stopped at traffic light, goes to 210-220. Upon resuming cruising, back down to 200 degrees. Has 195 t stat, standard no clutch 6 blade fan, no shroud.
NOW- return home park car, wait about a minute , then coolant peeing out the radiator cap, and the overflow tank!
Open for suggestions where to start!!!!
The radiator cap used with a coolant recovery system is different than a regular pressure cap. Are you using the correct cap?? It has a gasket to seal the cap to the radiator neck and allows the coolant to be brought back to the radiator when the the radiator cools off. Without the proper cap, the coolant will just pee on the floor.....Bad cap. 180° t stat.
I’ll be checking that in the morning, thanksThe radiator cap used with a coolant recovery system is different than a regular pressure cap. Are you using the correct cap?? It gas a gasket to seal the cap to the radiator neck and allows the coolant to be brought back to the radiator when the the radiator cools off. Without the proper cap, the coolant will just pee on the floor.....
BOB RENTON
Recovery tank is 20ozWhy is anyone shocked a car with a 195* thermostat runs 200 degrees?
That's the design spec.
How big is the recovery tank?
Does it work?
Agree on-
180 stat
shroud
clutch fan
