Just how big is this bird?I'll lower it in with my engine hoist![]()
And keep Rebel in the house.....
Enter the oil very slow. I do mine at 3 1/2 minutes per pound at 350.
That’s the rod and stand that goes in the cavity of the turkey so you can lower or lift the bird.
Determine the level of oil needed by putting turkey in the pot and fill with water above the turkey, remove turkey, mark level of water and that will be the oil level you need. Dry turkey and heat oil
Shut off the flame put turkey in the oil then start the flame back up
Have a 'fire extinguisher' handy & do it away from the house outside
VERY slowly-about a full minute to immerse.
Do not do indoors or in a garage!
Turkey is a healthy choice of food to eat. Why deep fry it?
Nothing to add except put some cardboard down around the fryer to avoid making a mess. Make sure you are away from any flammable structure, my neighbor's buddy burned his garage down when he tried frying inside due to rain...
Cold oil will saturate the turkey and render it useless. We have done a few. Follow the advice of the members. Kimany reason not to put the dry turkey into the fryer, fill it with oil, then remove the turkey until the oil is hot?
put some cardboard down around the fryer ................................. + Make sure you are away from any flammable structure,
sure...cardboard is not flammable at all.
