Less BS about changing tire alignment specs from stock (a.k.a. let's rant about Mopar suspension some more)
cudak888
6:11 AM
South Florida
Yes, this is both a snarky jab at this thread and @gtxrt's outdated ideas as to what constitutes good alignment specs for a B-body and a mindbarf of my thoughts and experiences about Mopar suspension. In my not-so-humble opinion, I'm hoping this thread might actually help those of us who are new to B-bodies.
Granted, I'm not sure how many I'm preaching to - the old car market is completely and totally plucking nuts for young people today and I'm not seeing that many young people taking on B-bodies if they haven't outright inherited them - but what the hell, that complete snafu of an advice thread needed a counterpoint rant thread to unpfluck it. And this is it.
As a relative novice to Mopars (only about 6-7 years as an owner w/only a 20k-mile A-body and my worn-to-hell-and-mechanically-refreshed '68 Satellite, plus some wheel time behind some other local A and B-bodies), if you want to understand Mopar suspension, advice #1 is to run away from threads where the information is fractured between 10 smart guys trying to explain to one or two curmugeons that they're wrong. Sadly, there's a whole lot of good information buried in that thread that's also incoherent for newcomers who are trying to wrap their head around why a B-body's suspension is more inscrutable than a tripolar girlfriend. If you're still trying to wrap your head around why your old Mopar handles like a wet noodle, you're just going to come out of this more confused than anyone.
I've come to grips with B-body suspension the hard way - research from reading the forum (especially @Kern Dog - I owe you more than a few beers for the outstanding advice you've posted over the years), reading up on suspension in general, experimentation on my own cars and throwing money at them judiciously (that's why it took so long to get here), and the knowledge gained from the whole enchilada. And no, I'm not done learning yet - as you'll see - but I thought now is a good enough time to start a thread about it.
Full disclosure: This is also my own way of looking at it. Maybe I'm the one that's wrong, but this has worked for me. Maybe it will for you. Or maybe it won't and I'm a moron - either way, I'm sure you'll let me know in the replies.
That said:
In my experience, lousy A/B-body steering feel can be exacerbated by one or all of these things:
-- No corrections to overcome factory suspension geometry designed for bias-plys
-- Bad alignment settings
-- Worn suspension components
-- The stock feeling of a Mopar steering box
All of these can work together to confuse the living hell out of you, especially as the result may not be what you expect. Let me try to break it down for you:
"If you have worn tie rod ends...pick up the phone and start dialing [your parts supplier].
If you have worn bushings...pick up the phone and start dialing [your parts supplier].
If you have worn anything else in your steering and suspension...pick up the phone and start dialing [your parts supplier].
I want you to deal with your **** suspension by reducing the number of factors making it shitty!" - The Wolf of Mopar Street
Got it? Good. (If absolutely nothing else, do your inner and outer tie rod ends, idler arm, lower control arm bushings, and strut rod bushings. The tie rod ends will play havoc with your toe adjustment, the strut rod affects your caster, and your LCAs will be flopping around everywhere if you leave them crusty).
Secondly, the geometry on our cars' suspension is designed for bias-ply tires and even then, it absolutely sucks. Chris Birdsong went down the rabbit hole of this recently, and if you're new to A/B suspension, don't even LOOK at his (excellent) video, because you don't need to know about correcting roll center (not now, anyway). You must walk before you run, grasshopper.
Also, it sucks worse for A-body owners because you can't get good caster with those cars without offset bushings or different upper control arms. We're playing in the B-body sandbox here right now though, so never mind the Dennis Weavermobiles.
First: Your ride height needs to be set right. Everything starts with that, and since our cars have torsion bars, any idiot can go down to the lower control arm and start futzing around with it. I won't explain how to adjust it - there are a bunch of other threads that establish this, and it's not difficult - but my word of advice is to ignore any measurements from the tire to any body part. If your camber happens to be wacky from left to right, there's no point in this measurement. Just get the car to where it's level or nose down a bit (another bit of advice by @Kern Dog - the geometry of our suspension tends to work a bit better if lower) and use the measurement of the adjuster bolt head to the lower control arm as your data point for leveling one side to the other. Again, if your camber is wacky, the correct measurement at the LCA's may look completely wrong when you look at the car (before everything else gets adjusted) - case in point, not only was the left side of my Satellite lower by 1cm on one side, the top of the wheel was tucked in an entire 1.5" further away from the fender due to excessive camber.
And another thing to get tripped on here: Roll the car a lot when setting the torsion bar height. You'll probably be jacking it to get the load off the bolt, but that'll also get the front of your car to to sit like a Volkswagen with a swing axle if you let the tread off the ground when doing so. Take note that the old "bounce it" advice for settling the suspension is about as helpful as a porcupine at a nudist colony - it doesn't work unless you have the wheels on turn plates so the tires can slide into their happy place. Otherwise, if you're doing it the way I've done it - tread to concrete (a.k.a. the cheaparse lazy method) - it doesn't work; the tread needs to find its happy place and settle. Doesn't matter if it looks wrong, just make sure the wheels aren't at an aggressively pinched V shape mimicking what it looked like when the wheels were off the ground.
Second: You've seen this skosh chart reposted a million times (thank you @toolmanmike for invoking it as early as post #2 in the original thread), and you can now look at it for the 1,000,001th time:
If you're just looking to start from a decent baseline, heed these numbers. This has been reposted a bajillion times for good reason: It pretty much is a great starting point for any old RWD street (not track) car from this era with conventional control arms.
If you can reliably get anywhere between:
1. -0.5 to -1 degree of negative camber,
2. As much caster as you can get (if you can get "too much caster," you've already modified your car, probably know more than a newbie, and shouldn't be reading this Cudak888's B-body Alignment for Dummies post),
3. 1/16" of toe in
...then you should have a baseline that will result in a car that, if nothing else, tracks straight.
And you know what? There's a good chance you'll still be asking why your steering feels light and disconnected from the road.
Over my own years of ownership, I waded through all the threads on alignment here and at FABO I could shake a stick at. After stopping my head from spinning - first from all the information and secondly from all the money I threw at my pile of crap car - I realized you can still get lost even with the most straightforward advice, because even with ideal alignment settings, our cars - with stock components and corrected alignment for radials - will still feel "wrong" if your prior experience with 1970's steering is exclusive to Saganaw-style boxes. i.e., what you would find in GM vehicles and Fords made after the '60s (the ones that ditched the Rube Goldberg hydraulic ram for the Saganaw box - sadly, I can't comment on the ram steering as I've never driven a car with it).
My entire experience since childhood was with Fords (go ahead, sue me) built between 1971-1979 with Saganaw boxes. They're soft and overboosted, but they do not feel - in the spot-on words of @Kern Dog in one of the most important posts I've ever read on any Mopar forum - "like the tires are hanging in the air and not connected to the road."
The Mopar box feels like this, but when the only words used to describe all old car steering is "soft," "overboosted," or "one finger turns," there's no data point for the variations within old car steering. Take my word for it, trying to equate the feel of a Mopar box and a Saganaw box together is like trying to draw correlaries between a Mopar box and the super-tight rack-and-pinion on, say, a BMW E39 ("...cooooming up!"). They're different, and if it wasn't for the internet running with old car stereotypes, perhaps there'd be more information out there about how a Bendix/Garrison power ram feels vs. a Saginaw box vs. a Mopar box, vs. - I don't know, a Rover 3500 P6 power steering box (I want one).
Hey, I don't have the money or time to buy them all to find out and report back myself. Someone go find Derek Tam Hyphen Scott and make him do it.
Thing is, I must have spent years questioning this - I did so when I bought my Mopars, when I modified my '68 Satellite, when I went to the alignment shop with it and forced them to put in good specs and not the old bias-ply specs that somehow persist in all the commercial machines, and I kept asking this question after replacing every last bushing and tie rod end, throwing on Firm Feel caster-corrected UCAs, and having it re-aligned. (It has FMJ spindles in it, by the way, just so the Ehrenbergites can freak out).
Exhibit A: How to waste your money
Important: The caster-corrected UCAs were supposed to give me all the caster in the world. And it did: The damn thing now had, according to the shop, 6 degrees of caster, -1.5 of camber, and 0.11 degrees of toe. And it still didn't self-center or track straight, drove like crap, and the left wheel had enough camber in it to be a Honda Civic.
So, two days ago - after finishing a million other problems on the car and at least three years since the last trip to the shop - I finally - finally - went ahead and did a home brew alignment on it. Found a spot of the broken driveway where the car sat within a degree of being dead level, and went to town.
I figured I couldn't eff it up any worse than the shop.
Exhibit B: "Would you buy a used Mopar from this man? Your answer, should you be sane, is 'no.'"
I used a Joe's bubble gauge, one of those fancy clamps that fastens to the rim (because I don't want to be limited to the alignment bubble attached to a hub - I believe the Joes bubble gauge can't do so in the first place, unlike the Longacre models), and for toe, I used el-cheapo plates that rest on the side of the wheel (with modifications so they'd touch the rim and not the bulging tire) and one of those stick-style gauges, and also tested an old Align-A-Matic.
The plates - can post pics of the modifications later
The "stick-style" toe gauge, el Chinesium edition
The Align-A-Matic. This is the eBay picture. You can guess how well it worked.
I found about EIGHT degrees of positive caster on both sides, -2 degrees of camber on the left, -1.5 neg on the right, and enough toe in for a flock of pigeons. The car was riding an inch lower on one side because of the excess camber pulling the suspension down, even though the bolt heads on the LCA's were dead level at 1-1/16" out, each.
I farted with it for a couple of hours yesterday, and I'm pretty confident I got to +7 degrees caster after aiming for -0.5 camber and winding up closer to -0.75. I also found that the right tie rod adjuster was almost entirely wound in, but not the other side - and just by eyeballing the car and the steering wheel set straight, I wound up with roughly 1/16" toe in and just about equal threads on both sides - as one might expect. I was equally surprised to find that the plates worked very well, as did the cheap-looking stick-and-gauge tool, but the Align-A-Matic was completely off (eBay time - LOL).
And so I took it for a drive. I figured that now I confirmed how much caster I have, it couldn't be too bad.
Well, going right back to @Kern Dog's Most Important Words of Wisdom Ever:
If you’re stating that the steering feels like the tires are hanging in the air and not connected to the road, sorry to inform you….
That is how many of these cars were when new.
And now I know this for sure.
Point 1: It tracked straight and felt 10 times better, if compared with how it felt before. Moral of this story, #1: Do your own effing alignments.
Point 2: It feels EXACTLY as Kern Dog says - as if the front end is being yanked off the ground at 120mph and getting light.
Point 3: It also somewhat self-centers now, but still needs a bit of a yank during the last quarter of the turn. And now I know that's how these damn things feel even with seven freaking degrees of caster in them, even if the box is self centering correctly.
So I both succeeded (#1) and found out that what I'm after will never happen with a stock steering box (#2 and #3).
More importantly, without going through this entire rigamarole first hand, I would have never really understood what I was dealing with and would still be questioning why seven degrees of caster wasn't resulting in neck-snapping return-to-center behavior and further second-guessing even the good information on the forums. It's a testament to: A. Why it's so important for alignment information to be correct and well presented (a.k.a. free of BS), and B. Why there's NO substitute for hands-on experience and a good mentor with even more experience (we put our faith in Blast Hardchees- I mean Kern Dog!) to explain when something simply doesn't add up.
I can't recall anything I've done in the last five years that's taken me to school harder than this - no amount of caster on our cars can make up for the steering box, at least, how I expected it to act with the increased caster.
What's more, @Kern Dog yet again dropped the greatest wisdom (and a great big middle finger to my pocket book - I was already fretting the cost of the FFI box) with this:
I had a FF Stage 3 steering box in my car for over 20 years but maybe less than 15,000 miles. It was great for awhile but the internals wore enough to where the free play was just too much for me. I’m told that free play is a design flaw that all Mopars had and that no amount of work can fully eliminate it. Many guys have swapped in a Borgeson steering box and been happy with it.
I've been looking for something substantive like this regarding the FFI/S&G/Borgeson boxes for a long time, especially when David Freiburger emptied his pocketbook to install the Borgeson on General Mayhem. I knew there had to be something in it for him to spend $1k above the cost of an FFI box for that beautifully restored rotbox (don't get me wrong, I love General Mayhem and know it's a darn fine B-body ever since Birdsong restored the unibody). Kern's comments above answered every other question I had.
Now, maybe I'm blowing smoke out my own butt, but I had to vent after reading all the nonsense that @gtxrt was posting in the other thread. Yea, he's entitled to his opinions, but alignment is too important a functional safety feature of any car for actual BS to sit around the internet thick as peanut butter, especially when - again, in my not-so-humble opinion - straight answers are hard to come by. It's even harder to find words of true experience like Kern's that actually reflect the various aftermarket fixes for them and are worded in a way that one can understand the tactile differences of each box through mere words.
I'd add more to this, but I don't really have anything else to say...so here's a photo of the '68 Satty, because :xscuseless:
-Kurt
did you read all the posts ? i said i have manual steering why would i want all the caster i can get ? I also said the car drives and handles very good now better than a stock 1967 b body did from the factory and if I had power steering I would do more positive caster.
I've come to grips with it the hard way - research from reading the forum (especially @Kern Dog - I owe you more than a few beers for the outstanding advice you've posted over the years), research from reading up on suspension in general, experimentation on my own cars and throwing money at them - judiciously (that's why it took so long to get here) - and the knowledge gained from the whole enchilada. And no, I'm not done learning yet - as you'll see - but I thought now is a good enough time to start a thread about it.
That said, this is also my own way of looking at it. Maybe I'm the one that's wrong, but this has worked for me. Maybe it will for you. Or maybe it won't and I'm a moron - either way, I'm sure you'll let me know in the replies.
All of these can work together to confuse the living hell out of you. Let me try to break it down for you:
Got it? Good.
First - your ride height needs to be set right. Everything starts with that, and since our cars have torsion bars, any idiot can go down to the lower control arm and start futzing around with it. I won't explain how to adjust it - there are a bunch of other threads that establish this, and it's not difficult - but my word of advice is to ignore any measurements from the tire to any body part. If your camber happens to be wacky from left to right, there's no point in this measurement. Just get the car to where it's level or nose down a bit (another bit of advice by @Kern Dog - the geometry of our suspension tends to work a bit better if lower) and use the measurement of the adjuster bolt head to the lower control arm as your data point for leveling one side to the other. Again, if your camber is wacky, the correct measurement at the LCA's may look completely wrong when you look at the car (before everything else gets adjusted).
Second - you've seen this skosh chart reposted a million times (thank you @toolmanmike for invoking it as early as post #2 in the original thread), and you can now look at it for the 1,000,001th time:
3. 1/16" of toe in
I used a Joe's alignment bubble thingus dingus, one of those fancy jigs that fastens to the rim (because I don't want to be limited to the alignment bubble attached to a hub), and for toe, I used el-cheapo plates that rest on the side of the wheel (with modifications so they'd touch the rim and not the bulging tire) and one of those stick-style gauges, and also tested an old Align-A-Matic.
The "stick-style gauge thingus dingus" - too lazy to find out what this is called when it's not keyword spammed
The Align-A-Matic - this is the eBay picture. You can guess how well it worked.
Honestly, without going through this entire rigamarole first hand, I would have never really understood what I was dealing with and would still be questioning my car and even the advice on these forums. But there's NO substitute for hands-on experience, and I can't recall anything I've done in the last five years that's taken me to school harder than this - no amount of caster on our cars can make up for the steering box.
I've been looking for something substansive like this regarding the FFI/S&G/Borgeson boxes for a long time, ever since I saw David Freiburger empty his pocketbook to install the Borgeson on General Mayhem. I knew there had to be something in it for him to spend $1k above the cost of an FFI box for that restored rotbox (don't get me wrong, I love General Mayhem). Kern's comments above answered every other question I had.
-Kurt
This site needs a hot air button.
Waaaay too much to read even just trying to breeze thru, but I did get a big kick out of the last line!
Oh, I read your posts. Some of them were even coherent. :p
-Kurt
Another spec that needs to be in the alignment equation, and very important, is the "Thrust Angle". This is the measurement between rear axle center and front spindle center. Having this measurement off is why you see vehicles going down the road with the back end of the car coming around like you're drifting. Causes for this being off could be possibly corrected by putting shims between the rear spring hanger and unibody or adjustable front strut rods.. More severe issues could point to a bent diff housing, sheared spring center bolt, damaged unibody structure which needs to be taken care of.
You're very correct in that doing your own alignment may be the best fix. I'll need to investigate doing this too plus figure out a way to get the Thrust Alignment in there too as a DIY. Time to get crafty.
Hey, Kurt....
That took a LOT of time to write but it will help people if they take your advice. You humbled me with your comments and it feels good to know that my thoughts and comments have helped you.
I love these cars. I want to see others get as much out of them as I try to. It feels like some people struggle and short-change themselves by building the cars to what they think are factory correct specifications. What we know (And what everyone else should know) is that these cars were built in a time where all cars had primitive tires that left a LOT to be desired in terms of ride, handling and wear. It has been written that the race tires of the late 60s-early 70s are inferior to a decent street tire available today. It all starts with the tires. If you were to use that "Skosh Chart" on a car with a stock ride height and Bias Ply tires, the car may not ride or handle much better. Bias Ply tires were not very forgiving for negative camber. They would squeal and wear out the inside edges quickly. Radial tires are much different there. They are more tolerant and forgiving of negative camber as compared to Bias Ply tires. Negative camber helps with cornering because as weight shifts to the outside tire, flex and body roll tend to push the camber positive. Starting out with negative camber counter-acts some of this. A tire that corners on just the outer edge of the tread will not hold the road as one where the tread is square and parallel to the road.
I am not trained or schooled in any of this. Everything that I know was learned through hands-on experience and from reading books and magazines. I don't know everything....I am always learning and sometimes having to change my perspective when an opinion gets proven wrong.
Getting proven wrong can sting a bit but I'd rather learn and improve myself rather than to keep doing something WRONG just because I've always done it this way. That phrase and mindset just pisses me off. I've heard it from Carpenters, office workers, Politicians, friends, all types. Some people are either afraid of change or are just stuck on tradition to where they never evolve.
I take what I read and hear and try to apply some common sense to it.
Rick Ehrenberg is a smart guy but sometimes even the smart guys like him get it wrong. He was a harsh critic against using the later "B" steering knuckle/spindle in a 1972 and older Mopar based on the belief that the 3/8" taller knuckle height would result in a bind of the upper ball joint during suspension movement, specifically during full Compression/Bottoming out. His engineer brain made the assumption without ever actually testing this theory in a real world setting. Bill Reilly did though. I don't care for his RMS coil over suspension but he did take the time to do the research and write
an article for Mopar Muscle magazine around 2006. He found that the later (And 3/8" taller) steering knuckle used on all 1973 and later B bodies, all F-M-J-R body cars fits fine and has no issues with upper ball joint issues at all.
Oh, I really dig the 4 door vibe. The government issue license plate is a period correct look too!
One has to remember that in the 40s, cars were a bear of a clunky machine to drive. Then came the 50s with new inventions to make them easier to drive, something matic this, something matic that.. then the 60s, where they didn't even want you to know you were driving a machine. Hence the smooth automatics,, push buttons, power vent windows etc. Steering was a major point of contention . The easier to steer, the better. ( remember half of the drivers were now women, right?) Therefore the p/s boxes and alignments were set for " driving on a cloud of *******"
Now we've come full circle to making them aggressive track machines, like their newer brethren.
I like *******.
I don't want to drive on them.
I like *******.
Drool maybe. Windshield wiper or radio operation too.:lol:
As I get closer in the future on the 65 to get into the alignment, I'll look to score some other the necessary pieces for it plus figure out a way to make up some sort of laser measuring setup for the T/A in the equation. I also have the charts/graphs for bump steer specs and what needs correcting if its off, from the old Mopar Circle Track/Kit Car book.
Hey, Kurt....
Honestly, I just wanted to share it all - the frustration over chasing the front end, the difficulty of finding good information, the success (to an extend) of finally getting the car properly aligned and the eureka moment of "yes, these steering boxes really do feel like this...caster can't solve everything."
You earned every bit of the praise - I'm sure it has taken many hours for you to write everything I've read, multiplied tenfold for the amount of time it took to learn it. If I'm ever on the west coast, I owe you a few beers (or whatever libations suit your fancy).
I should point out, the only thing I diverted from - with some trepidation - was your recommendation that these cars do better with the front lowered. If I recall correctly, this helps with caster across the sweep of the suspension (correct me if I'm wrong) but I figured that with the Firm Feel arms already correcting caster, it would be advisable not to experiment with that.
Plus, I'm running huge 235/75/R15's all around, and the tires are currently happy clearing everything right now. Lowering it might not have the ideal effect.
Your approach is admirable and we should all aspire to be this open-minded. It helps to get things wrong sometimes too - it makes it a lot harder to make the mistake again the next time!
It's a shame that those who are honestly knowledgeable about this stuff and have the oxygen of publicity just won't admit or correct it, even when they're proven wrong (there's a few cases of this relating to the Diamonds are Forever Mach 1 that I'm dancing around right now). Ehrenberg could have shed a lot of the crap he still takes (and I give) over FMJR spindles if he simply had acknowledged his mistake when Reilly published.
The funny thing is, even after all these years, Ehrenberg's information still gets discussed far more than Reilly's article in Hot Rod, and I'd even forgotten the latter existed over time. Linking it here for those curious: https://www.hotrod.com/articles/mop...0503_03_z-disc_brake_spindles-a_body_spindles
It would serve many to learn the Fiorello La Guardia approach of owning up to an error: "I don't make many mistakes, but when I make one, it's a beaut!"
-Kurt
It does help but you make an excellent point. The self centering is influenced by the steering box by some degree. I'll add though that a tire that is really wide will induce more of the self centering since you can see that large amounts of caster will cause the wheel to take on a bit more negative camber at full left and right. This tilts the tire on it's edge which takes effort to do. That effort means resistance that you as a driver has to overcome with additional steering effort. In other words, wider tires may result in better self centering response.
I'm not a beer drinker or any alcohol, really. I do love a good cheeseburger though!
You know, I never followed the factory method for ride height settings. Yeah, I know....it is the "correct way" but I always adjusted the torsion bar bolts to get the tire reveals as close as possible. By the time an old Mopar gets to me, it has probably had 3-10 owners, maybe even had the front end rebuilt at least once. My red '70 was pretty original when I got it....
You can see the tops of the tire, a 215-70-14 which is listed as being 25.9". The next picture is with a 275-40-18 which measures 26.7"
The tire is about 3/4" taller but you can't see the top of the tire here. Just a guess but the front looks to be at least an inch lower here compared to the picture when the car was green.
Holy crap, that tire is listed as 28.9" ! That is tall.
I hate hypocrites. I also hate people that are so close minded, they have lost the capability to learn.
The funny thing is, even after all these years, Ehrenberg's information still gets discussed.
I don't want to cut the man down. I have learned a lot from him. I agree with him on most matters. The cancellation of the Mopar Action magazine is a terrible loss to many, myself included.
You guys might know the answer to this riddle. My 69 GTX has a lot, and I mean a lot of negative camber on the pass side. You can see it. Drivers side has maybe a little. It’s never been measured since I’ve had the car. I took decades old bias ply’s off as soon as I got it and went with redline radials. I couldn’t tell you how it’d do with bias plys as those were so rock hard it was a harrowing 20 miles at no more than 40 to get the car home.
It drives well I have to say. It’s a totally stock 70k mile car, I don’t push it around corners. It feels fine in this big sweeper out by the industrial park at say 90. I’d have to drive most of an hour to get out where you could really play in turns anyway. Cars everywhere here.
The camber is so much you can see a difference in the sway bar links. Kicked over a bit on that side where the driver one is basically straight. The ride height looks similar side to side, again I haven’t measured so just eyeballed.
Any reason they would have done this on purpose? I’ve thought about trying to even it up when I do the next set of tires, but obviously this works for my use of the car. ??? Do I open Pandora’s box?
Got it? Good. (If absolutely nothing else, do your inner and outer tie rod ends, idler arm, and strut rod bushings. The tie rod ends will play havoc with your toe adjustment, and the strut rod affects your caster).
3. 1/16" of toe in
-Kurt
I was an auto mechanic in the 1970's did a lot of alignments, and on the proper tracking, you have to adjust the suspension to pull against the crown of the road. More camber less caster on the drivers side wheel by 1/2 degree. If you do that you can let go of the steering wheel and it will go straight. If you add more than 4 degrees caster you run the risk in inducing caster shimmy, which can cause you to wreck the car. Even with offset control arm bushings I find it hard to get 4 degrees caster. The best way to get a good feel from the suspension is to replace the bushing in the frame for the brake reaction strut rod, the rod that hooks to the lower control arm. I even like the ones with a hiem joint if you don't mind keeping it original. Next is the lower control arm bushing, if these are loose and most are, it will never drive right. And since you have to remove the torsion bars to replace them, a lot of guys just don't do it, I know I have fixed lots of show cars that had everything else new but that.
Sounds like you're due for some lower control arm bushings.
Boy, I sure am glad I ditched my stock suspension for tubular rack and pinion coil over. Jeeze Louise.
"More than 4 degrees of caster could cause caster shimmy" ???? I've ran 4 1/2 degrees for about 20 years and have since switched to QA 1 UCAs that allowed 8 degrees. There is no shimmy of any kind. I've never felt anything that could be describes as a shimmy from the caster in anything. Maybe the alignments you did in the 70s were on Bias Ply tires or cheap radials?
I've done it twice in B bodies but the A bodies that I have done it to seem to result in less caster than I could get with the B bodies. Lowered ride height does help though, as shown in published alignment curves.
Good points made here.
What makes you think that? The coil over stuff is inferior in every way except for header clearance and oil pan access.
