How is that? Don't many machines also reference directly off the rim flange?
Once the sensors are attached to the rim the wheel is spun and it reads any runout.
Like mentioned by RemCharger, check those bushings. Add to that checking inspecting the sleeves in the K-frame that the lower control arm shafts mount to. Known to crack welds/wallow out giving you issues. Then the possibility of either upper control arm mounts not being where they are supposed to be welded on, maybe a Monday or Friday car, or possibly the frame rail is rolled around at that point. Prior damage that didn't get fixed? Time for some Columbo work investigating.You guys might know the answer to this riddle. My 69 GTX has a lot, and I mean a lot of negative camber on the pass side. You can see it. Drivers side has maybe a little. It’s never been measured since I’ve had the car. I took decades old bias ply’s off as soon as I got it and went with redline radials. I couldn’t tell you how it’d do with bias plys as those were so rock hard it was a harrowing 20 miles at no more than 40 to get the car home.
It drives well I have to say. It’s a totally stock 70k mile car, I don’t push it around corners. It feels fine in this big sweeper out by the industrial park at say 90. I’d have to drive most of an hour to get out where you could really play in turns anyway. Cars everywhere here.
The camber is so much you can see a difference in the sway bar links. Kicked over a bit on that side where the driver one is basically straight. The ride height looks similar side to side, again I haven’t measured so just eyeballed.
Any reason they would have done this on purpose? I’ve thought about trying to even it up when I do the next set of tires, but obviously this works for my use of the car. ??? Do I open Pandora’s box?
Is that why they call them "casters"?Nope push a grocery cart fast enough and the wheel will caster shimmy, grocery carts have lots of positive caster.
His picture is shown measuring from the rim, tire bulge is irrelevant in that case, I can't see rim runout being a significant factor here if we are using tape measures. A simple spin test visually will indicate if it is enough to be concerned with IMO.
Here is what I saw.As jc62 stated you stay away from the tire bulge and measure to the rim itself. I do check runout of the rim because I've had the problem in the past with inferior rims. Once set up on the alignment machine the sensors take in account for any runout.
What I posted is to get you close to specs before finding a good shop with a alignment machine. You can see from the readouts how close I was. I wouldn't accept my settings as final.
Did OP consider putting a BMW steering rack on a b body? That got my attention because of this:
He put an e36 front end (90's bmw 3 series) in a 69 satellite and was built recently. I have not seen that done before, but it appears to handle extremely well. There is another video of this car on a road course.
For some reason I can't wrap my head around what is the likely disparity in just track width between the E36 and the B body, or all the mods needed to get a proper fit, and then ask myself, why, just to get a R&P? I have huge respect for the Bimmer and have owned a few, 320, 635, and a 735, all drove/handled great, IMO it was the fine tuning, not the hardware.
Again, I can appreciate the low buck efforts as I too embrace that sort of thing but I see measuring off of a bulge at the bottom and no bulge at the top as being inaccurate. Whatever camber you find here seems to be mixed in with the bulge of the sidewall.
Definitely nothing wrong with 4 doors...
I believe you get the worn parts replaced, the alignment set and enjoy the ride.
When I did front end work at Mopar dealers no one ever complained about the front ends. We liked the easy steering.
Coming from a hot rod and racing background where solid axles were the norm I like old cars to drive like old cars.
