66 Sat
I've just fitted bolt-in subframe connectors to my car and confirm they make a HUGE difference, just in normal driving.
I fitted them this past weekend and drove the car this afternoon. It felt immediately better, much tighter, and cornering is a revelation, it stays so much flatter, but it's better in every way, acceleration, braking, the lot.
I went with the Competition Engineering ones from Sunmit. Very well made, black powder coated finish. Total weight of both connectors, bolts and plates is 12kg.
One thing I will say - they are a pain in the *** to install. They are made to very tight tolerances (with regards to the bolts and the holes in the connectors and the support plates) but unless the holes you drill are as perfect in terms of tolerance, then getting the bolts through will be painful, and will require some enlarging of holes, which defeats the purpose of the tight tolerance...
Welding them in would be easier and quicker. I used a magnet and vacuum to clean up the thousands of metal shavings left behind in the box sections after drilling.
Mine are in, and tight, but I'm going to weld them as well to prevent any future potential loosening.
Also consider access - you physically can't get a drill at the correct angle for the rear outside top hole as the sill is in the way, so you need to drill through from the centre of the car outwards, but then your muffler might be in the way. I used a 90° drill adapter to drill a pilot hole from the outside so the main hole didn't wander when going through the outer wall of the box section, and luckily I had enough room as I have cylindrical glasspack mufflers.
I'm amazed that what I've always perceived as the flex in the suspension components, steering, tires etc was mostly in the chassis itself. I'm sure the welded through the floor connectors would add something extra again, but just tying the 2 halves of the car together must surely achieve most of the same effect. I'm super happy with the result.
