Orig69
- 11:22 AM
- May 16, 2021
- Toronto Ontario Canada
I have a dual plane intake manifold so I use the original valley pan.View attachment 1813867
I was going to use this and go for a drive then do it again. Almost finished sealing front of radiator. Bottom hose now has spring. New coolant and water wetter. I also think I’ve found my oil leak I’ve been trying to locate since first start. It’s the valley cover. But have you ever seen one that is beveled and wedges under the heads? How the f@&$ am I supposed to fix this?
View attachment 1813868View attachment 1813869
Did you have to install the valley cover first before installing the cylinder heads?
