Why it happens:
It all starts when the over-running clutch (aka the sprag) in the rear of the transmission case is damaged. The roller bearings will commonly "roll-over" the posts or fingers on the spring retainer. This action will cause the transmission's geartrain to over-rev the engine rpm multiplied by the first gear ratio, commonly 12,000 rpm or more. The stock OEM powered forged high gear/front clutch drum retainer will explode at approximately 9,000 rpm. The sprag can be damaged by one or more of the following:
1) Driveline failure such as:
-Broken ring and pinion
-Broken u-joint or u-joint straps
-Broken driveshaft
-Broken axle shaft
-If you have a driveline failure, remove the transmission and carefully inspect the case and tail shaft area for cracks. Disasemble the transmission and check the sprag in the back of the transmission case. If it is not damaged, it is recommended to replace the springs and rollers to be on the safe side.
2) Using a reverse manual or trans brake valve-body that does not apply the low/reverse band in first gear.
-Ask the manufacturer of your valve body if it has the low bandy apply feature. This is very important, and I blame the majority of transmission explosions on valve bodies that are not applying the low/reverse band in first. If your car "free wheels" in first (early turbo action valve bodies), it is not applying the low/reverse band.
3) Misuse/abuse on the street or strip in first gear.
-Remember you can only damage the sprag in 1st gear. Start your burnout in 2nd, and shift to 3rd. When on the street, repetitively getting in and out of the throttle while in 1st gear can damage the sprag.
Transmission/sprag/drum explosion only happens in 1s gear. You either start in first to start your burnout and shift into second without over revving, or you start out in second with a manual valve body
-Broken driveshaft
-Broken axle shaft
Its happened with spirited input but nowhere near full throttle.
