Open to help here. 400/512 stroker. Herbert hyd roller cam, 485/500 1.5 lift. 64 Sport Fury convt, 4 speed. I've been looking into heads. I would go 440 source, but by the time you make all of the changes for roller cam, you might as well go Trick Flow. I had bought proform roller rocker setup a while ago, looks like that's not compatible. Recommended rocker setup is Harland Sharp specific to Trick Flow. I'd like to but don't have to stay away from needle bearings. Mancini and PRW have rockers less expensive, but will those work? Will I have to upgrade them too? This is a spirited driver, not a track car. Open to suggestions, and help me ask or provide the right input to clarify things. Thanks.
