Found this post:
Post
maximum amperage thru this system is right at 4.0 amps--which happens when key is on and there is no rotation of the distributor----then is drops to about 3 amps at idle and declines to about 1 amp at 5000 rpm (when firing 8 cylinders).
Similar search on HEI module draw indicates a similar story, ~6 amps (powered on, not running) falling as rpms rise. Extra power is dumped off as heat when module is powered which is why you need the heatsink.
Not sure if anyone here knows if the draw difference between the factory electronic ignition module and the hei module are enough to warrant wiring changes or not. Was hoping to avoid cutting up my new harness when I install it.
Post
