BLK 68 R/T
- 12:40 AM
- Jan 10, 2016
- Taxington state
Two things I can think of for the fore/aft movement limits of travel.Since I've never installed a roller cam in an engine that wasn't built with one, I still wonder about how all this will work.
The concept of the back side of the camshaft sprocket riding against the block seems weird even with a Torrington bearing. I haven't looked into how the cam button is modified for the required fore/aft limits of the camshaft. The limit that I read was .010 of an inch fore/aft. That confuses me, since the lobes in a roller cam are not tapered, the roller wheels on the lifters seem like they'd be fine with the wheel hanging off the edges a little. I'm just curious as to why they are supposed to restrict the fore/aft movement so much.
Back to the clearancing of the cam button....
I may buy a reinforced timing cover or weld a plate over mine. That makes sense.
Regarding the cam thrust button....
Let me guess....You must first measure the depth of the timing cover and gasket, then measure how far out the cam button sits out from the face of the block.....then somehow mill down the cam button to get to a number that is less than the depth of the timing cover by no more than .010.
I'm supposed to use a straightedge and plane across a tiny cam button to the face of the block? How is that done with accuracy?
1. Any fore/aft movements will induce sliding instead of rolling of the lifter wheel.
2. Stress on the oil pump/dizzy drive gear.
When I did my motor I used one of the roller style cam buttons.
https://www.jegs.com/i/COMP-Cams/24...MIg-etpvjrjQMVUgKtBh2L4BwYEAQYASABEgId7_D_BwE
