Knocking sound with manual trans
70CHRG
11:26 AM
New Zealand
I have a 1970 Dodge charger 440 RT with a 4 speed manual trans. Driving it home yesterday I noticed a knocking noise when accelerating in second gear. The knocking got faster as I accelerated and slowed down as I did. All other gears seem fine. Any suggestions where to start looking. Anywhere I can get info schematics of these transmissions.
It sounds like you have already diagnosed your issue.
Not yet. I guess its inside the trans. Is it likely to be a bearing or gears. I've never had one apart before. I haven't had the car for long and my understanding is the first and second syncros were done not long ago. When I strip it down is it likely to be obvious. Appreciate any thoughts.
When you pull it out, rotate the input and feel for the issue in second gear. Then pull the side cover and look for tooth issues.
Keep in mind that every gear is free-spinning with the cluster at all times. Only when a syncro sleeve is moved does the particular gear lock to the main shaft to drive the output. The fact that its second gear only is strange but my guess would be another syncro not fully disengaging and the teeth are still in contact.
Finally pulled my trans out today and took the cover off. I think I found the problem. The next thing is understanding the cause. One day it was fine the next it wasn't
Check the bottom of the gear box and see what you find besides the broken teeth. Maybe a needle bearing or something was dropped on accident by the rebuilder.
Now I just gotta get my head around what parts to buy and how to identify the correct ones.
Just starting to research the parts in my trans and would appreciate some knowledge around my main input shaft bearing. Was trying to measure up as to whether I had a 308 or 307 bearing. From what I can gather a 308 is 90mm OD and 40mm Id. 307 is 80mm OD 35mm ID. Measured my bearing and its 90mm OD and 35mm ID. So its neither. Width is 21mm which is what a 307 should be. A 308 is 23mm. There is no numbers on the bearing. Any ideas what I have.
Not sure on the bearing but wondered what the counter gear unit looks like. Is it messed up too?
Go on Brewers website and look at the various parts. They will have everything. You will be able to match things there, including your bearings.
There are specific 308 bearings for these transmissions. If you just look up a 308 bearing online you'll probably see 308SG which measures 90x40. The 308SG8 measures 90x35. Sounds like you have the 308 bearing.
[/URL]
Thanks for that clarification. I did look on the Brewers site but they only state the outside diameter not the shaft size. I don't need to replace it but am just measureing everything and making a note of all parts I have in my trans for future reference.
The best way to determine your bearing will be to look at the billet retainers on Brewers site. You likely need a 308 - chances are slim you need the 307
Still having trouble being convinced on bearing size. I looked up 308 SG8 dimensions and this is what i got.
A 308 SG8 bearing, often found in automotive transmissions, has the following dimensions: a bore diameter of 40mm, an outer diameter of 90mm, and a width of 23mm.
My bearing is 90 OD 35 ID and 21 thick
Would really appreciate some help on this. Not sure if my trans has been modified with parts from 2 transmissions hence a strange bearing size. (if it is a strange bearing size) Just doesn't make sense to me but i am very new to the mopar scene.
