1967bperko
- 11:51 AM
- May 15, 2024
- jefferson township pa.
I’ve had the cooling system thoroughly flushed and treated 2 times, so as to properly use Evan’s waterless coolant in my 1967Charger 383 4 barrel engine.All components of the cooling system are new including a 26 inch large tube aluminum radiator, new flow kooler water pump,new fan clutch and a new160 thermostat.For now I have the heater core bypassed . I‘ve bleed the air out of the cooling system.When I start out the engine is warm and the temperature is normal,after driving about 40 miles on the highway the temperature starts to go up to between half and three quarters,then I get off the highway and drive on a rural road and then the temperature goes back down to normal,about 1/3 of the way up on the factory gauge. Why is the engine temperature fluctuating like this.Please advise,Thanks Bob
