Mariposa Mike
I had a seeping oil pump on my 1966 383 Charger and purchased the seal kit after tightening the bolts but still having a leak. Removed the pump, replaced the seals (much needed), checked for any warpage/wear and installed the pump. According to the FSM it says to prime the pump..... before starting the engine I presume. I have the tool to do that after pulling the distributor but need to know how long to run a drill turning the tool to get prime. My oil pressure gauge is not working so I cannot check that for pressure. Was thinking I could pull the sending unit and put a pipe fitting there with a clear tube connected to see when oil has come that far. Would that be enough or is there a better way to do this? I hope someone has done this before after a rebuild or has a better idea.
