JARRETT LYNCH
- 10:03 PM
- Feb 11, 2022
- ANAHEIM, CALIFORNIA
its an EdelbrockThere is a recall on some Holley pressure regulators.
I know that but some mechanical pumps will produce more than desired fuel pressure and you have to lower the pressure down. For instance this Edelbrock is at 7psi, that pretty high for carburetors. A lot of carburetors would flood at this pressure. Mine isn't at this time, so i'm going to monitor. BTW. I had the regulator turned all the way out so the pressure should have been what the pump was putting out.A fuel pressure regulator ONLY reduces the fuel pressure. It will NOT increase the pressure, only a pump will do that. It seems that you might creating your problem with the regulator...
Not track approved?Hey just a suggestion, get rid of that glass inline fuel filter... they are not track approved and big fire hazards, use a metal one. For testing I get it but I just would hate to hear it burned up and I had mine leak on the intake never again.
I might try one of those. I replaced a Holly with a Carter, both overly loudBut... it's q-u-i-e-t. I gave up traditional pumps ( Holley red, blue, Carter, etc. ) many years ago. Too LOUD ! A gerotor pump is a different method of liquid delivery which results in substantially quieter operation.
Agree, had that model one for 18 months then a piece of the glue at the top that holds the filter got between the needle n seat and jammed it open fuel everywhere. also found out had no gauze filter on the seat closed to the inlet, there is another version plastic filter with metal caps on both ends.Be careful with the cheap plastic ones too.......
https://www.amazon.com/HayEastdor-Universal-Filters-Replacement-Motorcycles/dp/B0C34DCS25/ref=sr_1_3?crid=3UNOOAA32YCIX&dib=eyJ2IjoiMSJ9.0rlU7u2-chXZNJQZNdsOCjvFABYQmOX-z9XrZWKVN6U9mELrJA5n6o4o2pffgHSY2SHQlULO-UF0PGYsy_9-asKS4rEuGJkb2srJZJCgv--YF3KYSwpt61-E-Fx--XYjAhvvFjwfzBjDUmcasfrsh17xOJQ1PzG3awkHJ3mUKAdCaOOZkzlCkfPKYSN-Qo4lDi8s6tE4W3Ql-uLL0jeZS0jEPhvQ7vBGcKeIa67_dIY.7Flc6Nk2VshE1LjqCUcqJ5GjAteg-PJXCYxbPTulZ7Q&dib_tag=se&keywords=PLASIC+FUEL+FILTER+5/16"&qid=1755401692&sprefix=plasic+fuel+filter+5/16+,aps,182&sr=8-3&th=1
The Wix and Fram are all plastic, and most likely thermal bonded. The ones in the link are part metal and most likely crimped. I should have specified what I meant by "cheap". I've used the name brand plastic filters for years (on cars with questionable fuel tanks) and never had issues.Never had problem with Wix or Fram plastic filters.
Of course the lines running in and out of mine are completely straight putting no bending load on the filter body.
All the rubber lines I have are fuel injection rated hose- the good stuff.Standard rubber fuel lines nowadays? NO! If you run ethanol blends they rot and clog from the inside. Buy fuel injection rated lines, and use fuel injection rated hose clamps.
I am glad you got things working fine. I was thinking why anyone with a HP BB Mopar running a mechanical pump would do anything less than a Hemi pump. Why didn't I think about that when I had my 70Bee? Nowadays I concentrate on 1st Gen CTD's
B/RB & HEMI Mechanical Fuel Pump - 80GPH - 6PSI Manc
I just went in an bought the metal ones.All the rubber lines I have are fuel injection rated hose- the good stuff.
On a related note, shouldn't it be "taken to the cleaners" ???
