Butch Harley
Trap heat I made these
ECP 26" Aluminum Big Block Mopar Radiator - Big Cooling TubesSo i know a lot of guys have posted similar issues so bear with me....
Data:
22" aftermarket 3 core radiator
New clutch on fan
No shroud ( can't get anything to fit rad)
Put 3000 cfm pusher fan on front of radiator
Removed tranny lines and put new cooler away from rad
Tried all diff thermostats and ended up with just a restrictor plate.
New upper and lower hoses.
New "stock" CW water pump
New 15lb rad cap.
Car runs pretty cool for about 15 minutes and then temp creeps up slowly to 230+ when I turn off.
Have 2 guages and both show same hot condition.
Pukes water/antifreeze after i shut off steam, etc.
I give up!
Only other thing is to change radiator with one tgat fits a standard shroud but I can't find any that they say works with stock shroud.
So..questions:
1. Any other ideas other than rip engine apart and look for some obstructions (relatively new build with decent cam and big headers.
2. Any idea for 22" radiator that works with stock shroud?
3. Shoukd i ditch clutch fan and use non clutch?
Thanks for all your help
Agreed. Check the coolant for combustion gas first. Big blocks don't heat up very fast. Easy to do.First step get a co2 test kit from Amazon to check head gasket for leaks. Second if big block no more then 60 thousands clearance between impeller back side and facia of pump housing. Third you must have minimum 2/3. fan blade in some kind of shroud. Then 1/4 inch clearance max around edge of blades to id of shroud. The clutch mechanism you have is it a ac version or standard which makes a difference. The electric pusher simply put is bulshit with a proper cooling system, just b increases demand on alternator. Can you also tell us if the overheat is happening at hywayvspeeds or off idle
Yes, definitely start with the simple easy stuff. Timing and combustion gas check first. That way you don’t feel like a dumb-sh*t later on. I’ve definitely learned that the hard way!Agreed. Check the coolant for combustion gas first. Big blocks don't heat up very fast. Easy to do.
No use in telling the people the truth. As I have mentioned before, Chrysler would have gone bankrupt in the 50’s or 60’s if that was a poor design.Nobody wants to hear from me.. lol. 6 cars, factory rads.... none puke!
IIRC…I believe the inside dimension of the of the pump housing (water pump mounting surface to inside rear wall) was too large thus locating the impeller of the pump too far from the rear wall of the housing. Apparently that created a misdirection of flow with all that space behind the impeller. There was a measurable difference in that depth between the aftermarket one and the Mopar Perfomance one we ended up installing. Now the engine runs cool!And how do you know these housings cavitate? Is it because the engine overheats?
Same here. Seven GTXs, all factory stock cooling systems. Only two ever had overheating problems. Problem solved by re-coring the original factory radiator in each. Drove the current one to Carlisle this year, with no issues. Fellow FBBO member who parked next to me did the same with his Hemi car.Nobody wants to hear from me.. lol. 6 cars, factory rads and oe water pumps.... none puke!
What's the highest ambient you see in summer?Nobody wants to hear from me.. lol. 6 cars, factory rads and oe water pumps.... none puke!
Here's out driving at 33C, 40C with the humidex. Generally damn near 100% humidity up here in the summer, we are on the great lakes. This isn't Antarctica! NO puke... tune it, time it properly and drive! OH, that's 104F BTW...What's the highest ambient you see in summer?
But it's a dry heat.. LOL104f here is a cooling trend.
So is an oven, lol.But it's a dry heat.. LOL
Saturday morning, 12.55am, woke up by the dogs. Not unusual, they usually need to go potty about that time.But it's a dry heat.. LOL
