Cooling issues 69 RR 440 at wits end!
Trap heat I made these
So i know a lot of guys have posted similar issues so bear with me....
Data:
22" aftermarket 3 core radiator
New clutch on fan
No shroud ( can't get anything to fit rad)
Put 3000 cfm pusher fan on front of radiator
Removed tranny lines and put new cooler away from rad
Tried all diff thermostats and ended up with just a restrictor plate.
New upper and lower hoses.
New "stock" CW water pump
New 15lb rad cap.
Car runs pretty cool for about 15 minutes and then temp creeps up slowly to 230+ when I turn off.
Have 2 guages and both show same hot condition.
Pukes water/antifreeze after i shut off steam, etc.
I give up!
Only other thing is to change radiator with one tgat fits a standard shroud but I can't find any that they say works with stock shroud.
So..questions:
1. Any other ideas other than rip engine apart and look for some obstructions (relatively new build with decent cam and big headers.
2. Any idea for 22" radiator that works with stock shroud?
3. Shoukd i ditch clutch fan and use non clutch?
Thanks for all your help
ECP 26" Aluminum Big Block Mopar Radiator - Big Cooling Tubes
While a 26 would be better, especially if you have the core support for it. It’s not absolutely necessary. My dad had a ‘68 Polara with a 383. It had a 22” 2-core radiator that did ok, then he added aftermarket A/C. Later he bought a 19’ Prowler travel trailer. Then the cooling system couldn’t keep up. He got a 22” 4-core radiator, an external trans cooler, and a better fan and the Polara never overheated again, no matter how many dogs & kids and how much crap we put in that trailer. The factory drum brakes were another story!
First step get a co2 test kit from Amazon to check head gasket for leaks. Second if big block no more then 60 thousands clearance between impeller back side and facia of pump housing. Third you must have minimum 2/3. fan blade in some kind of shroud. Then 1/4 inch clearance max around edge of blades to id of shroud. The clutch mechanism you have is it a ac version or standard which makes a difference. The electric pusher simply put is bulshit with a proper cooling system, just b increases demand on alternator. Can you also tell us if the overheat is happening at hywayvspeeds or off idle
Agreed. Check the coolant for combustion gas first. Big blocks don't heat up very fast. Easy to do.
Yes, definitely start with the simple easy stuff. Timing and combustion gas check first. That way you don’t feel like a dumb-sh*t later on. I’ve definitely learned that the hard way!
A lot of stuff mentioned.
Compression ratio can be a factor. I have a 22” in front of a stock 383 no problem but my 440 with 11 to 1 has the biggest rad I can fit cause it needs better cooling capacity.
The mention of burping is very important. Not overfilling is also important. Checking compression for a head gasket is also good advice.
Make sure your belt is correct and doesn’t slip with your pulleys. It does make a difference. Timing a good start.
When you hit the accelerator while standing in front of the grill does it pull your pants towards the engine?
Will it overheat idling with the hood open?
Does it overheat the faster you go on the highway?
More stuff to check..,,
There is no denying that many vintage Mopars struggle with heat soak and high coolant temperatures in summer traffic. But that is not the radiator’s fault, not entirely. When you consider that most of these cars are 50+ years old and often run with:
  • Incorrect ignition timing or curve
  • Leaner-than-optimal air/fuel mixtures
  • Missing or ineffective fan shrouds
  • Weak radiator caps or improper coolant pressure
  • Cheap parts-store water pumps
It is no surprise that they run warm. But the issue is not the cooling system's design. It is that something else has gone wrong.
The Factory System Was Built Right
Original Mopar cooling systems were engineered to survive stop-and-go traffic, desert heat, and quarter-mile abuse. A well-maintained factory system typically includes:
  • A 2 and 3-core copper/brass radiator
  • A 4, 5, and 7-blade mechanical fan (sometimes with a clutch)
  • A full fan shroud
  • An appropriately rated 16 psi radiator cap
  • A correct thermostat (usually 180°F or 195°F)
Factory radiators were often larger and more effective than those used by GM or Ford in comparable models. When restored and paired with a finely tuned engine, they still do the job, proving their worth and reliability.
check Mopowergarage.blog for more information about Mopars
Just curious, you don’t happen to have one of those early 440 Source water pump housings do you? They were cast wrong and allowed the water pump to cavitate. Engine will overheat quickly no matter how much water you throw at it. Ask me how I know…
And how do you know these housings cavitate? Is it because the engine overheats?
IIRC…I believe the inside dimension of the of the pump housing (water pump mounting surface to inside rear wall) was too large thus locating the impeller of the pump too far from the rear wall of the housing. Apparently that created a misdirection of flow with all that space behind the impeller. There was a measurable difference in that depth between the aftermarket one and the Mopar Perfomance one we ended up installing. Now the engine runs cool!
Nobody wants to hear from me.. lol. 6 cars, factory rads and oe water pumps.... none puke!
Same here. Seven GTXs, all factory stock cooling systems. Only two ever had overheating problems. Problem solved by re-coring the original factory radiator in each. Drove the current one to Carlisle this year, with no issues. Fellow FBBO member who parked next to me did the same with his Hemi car.
Baby Blue had the original stock 22" radiator, with a shroud, and fixed seven blade fan. After the radiator was re-cored, I drove the car to Carlisle almost every year, and it ran cool, even in 95 degree heat and humidity, including the long idle in traffic waiting to enter the show field.
What's the highest ambient you see in summer?
Here's out driving at 33C, 40C with the humidex. Generally damn near 100% humidity up here in the summer, we are on the great lakes. This isn't Antarctica! NO puke... tune it, time it properly and drive! OH, that's 104F BTW...
But it's a dry heat.. LOL
Saturday morning, 12.55am, woke up by the dogs. Not unusual, they usually need to go potty about that time.
This time they are really agitated. I realize we are in a pretty big thunder and lightning storm. So at 1am, at still over 100°F, I'm running outside to put the windows up on the trucks.
1:05, massive wind and rainstorm hits, GF wakes up, says WTF is that?
1:10: power goes out. I tell the gf I'll hook up the generator in the morning after it gets light.
6am: wake up, expecting no power, but the a/c is on. Hooray!
Wait. Oh crap! Lakes everywhere, three trees down. Okay, good morning after all Two of em could fallen on the house and didn't.
So far, two of us working from sun-up to too-dam-hot for two days. Only two and a half trees to go.....
A cooling trend would be very welcome.
