- 3:06 PM
- Jul 1, 2015
Perhaps you should review the excellent works of "CRANES FLOW OF FLUIDS" which analysis the phenomenon of turbulent flow vs laminar flow or the differentiation of the Reynolds number criteria. YES.... AIR, is considered a fluid.....The other factors to be considered are velocity heat, friction head, total system pressures, viscosities of the pump age. Fouling factor must also considered as well, as it has a tendency to slow the overall velocity effect. BTW.....what's the differential point between laminar flow vs turbulent flow. Velocity is key as we're moving BTU/HR, from a HOT AREA to a Cold area......remember.....in order to accomplish work, you must flow down a temperature gradient,F Dave, fast flow, friction, the heat it adds while dissipating nothing... wtf do we know. Ever put too small size of lines on a backhoe hydraulic system and stuck you hand on a metal section.Laminar, turbulent flow, wft do I know !
it's not a matter of a collapsed lower rad hose, a 1/8" diameter hole in the tstat valve plate or whether coolant recovery is present or functional. Learn how things work...and why....don't just take the word of the inexperienced........just my opinion.......
BOB RENTON
