Also no real set timing really goes by what curve the distributor has in it for that setup. Also if your ant EMP the alternator goes and a generator is needed.
Sarge, would you mind explaining that in more straightforward terms?I like points a good set will give you 10K of driving. Voltage to the coil is controlled by the ballast resistor. For points you want .05/.6 ohms. That is with a 1.5 ohm coil. It will run fine with the other systems on the car.
when in start position, full battery voltage will be applied. In the run position, the circuit to the coil is through the ballast resistor and will probably be 7–9 volts if things are in good working order.Sarge, would you mind explaining that in more straightforward terms?
I have a 1.5 ballast and a stock coil (compatible with a lot of makes over many years). The distributor and coil that I installed are compatible with 1972 400.
9 + volts at the coil is acceptable?
Should have saie the ballast for points .5=.6 and the primary resistance of the coil 1.5 ohms.Sarge, would you mind explaining that in more straightforward terms?
1.5 ohms Coil
RU11 seems to meet your recommended specifications:
Cold Resistance:0.5-0.6 ohms
Operating Resistance:1.75 ohms
Is a reading of over 9 volts on the positive terminal on the coil anything to be concerned about?
Since I most likely do not have the correct ballast resistor, will the voltage to the coil change when I buy the new (RU11) ballast resistor?
Wait for it.........You ought not have said that. 3, 2, 1,……..
