I wouldn't stop driving my car at 200 at a stoplight. That's not hurting your engine. The thermostat housing is water leaving the engine.
I definitely have zero flow restrictions. It looks like the Colorado rapids inside the radiator looking through the filler neck.This is a myth that seems to stay alive despite it making no sense.
Conversely, coolant that dwells in the radiator longer also allows coolant to dwell in the engine longer, increasing the heat transfer into the coolant.
200 is pretty fast. Even with an overdrive and tall gears, I doubt you'll get over 160 mph.I wouldn't stop driving my car at 200 at a stoplight. That's not hurting your engine. The thermostat housing is water leaving the engine.
Straight water with a wetter would have been best, but in the current state I'd be checking the over concentration of AF , which cools poorlyActually, they used 2 gallons of concentrate and filled the rest with water.
I agree. I have the one with the 5 color beads.Straight water with a wetter would have been best, but in the current state I'd be checking the over concentration of AF , which cools poorly
That's what I get for speed scanningThis has a roller cam. So, just breaking in the piston rings by driving 500 miles.
The FSM says 18 quarts for a 26" radiator equipped car with AC. That's 4.5 gallons.Yes and that comes out to more than a 50/50 mix as an A/C car holds just shy of 4 gallons total.
They're a staple of life up here. Unfortunately modern civilization doesn't believe in them anymore.I got to get me one of those fancy hygrometers like the one above in the comments.
I forgot that small detail. The high flow thermostat is a Robert Shaw by FlowKooler.High flow is where it's at. Hope its a Robertshaw/Stewart and not a Mr Gasket - Mr Gasket goes shut when it fails :-/
Personally, I wouldn't replace the FlowKooler yet. Those are good pumps. I have not used one on an ac car, but have run them on 4 of my non ac cars.I wonder if there FlowKooler is flowing too fast nit allowing enough time for a thorough heat transfer. I may try swapping it for the 6 fin stock water pump for AC to match the factory AC pulley size.
According to Bouchillon Performance Engineering, the crank pulley is 7-7.5 inches in diameter and the water pump pulley is 5.875 inches for the proper drive ratio.
Ordered a refractometer to test the antifreeze.I got to get me one of those fancy hygrometers like the one above in the comments.
