gtxrt
not sure what ones to get. like to get the weld on ones . 1967 dodge coronet.
any photos ?I have used a couple sets of the US Car Tool ones and they have fit quite well. As always there will be variations between cars so some fitment will be needed.
I've also put USCT ones on my 67 and they fit ok. Way more beating the floor pan down to fill gaps than I expected.
Nothing goes "right on".
am sort of hooked on these. need the c3117 for b-body found them for 203.00 total with shipping. can you weld these ?
The def look nice. I cut and grinded on them quite a bit.you can eliminate the front tab if the gap is wide.......makes it tighter to the floor and flush with the front rail
either way.... it's a good look
These were installed on a car I bought, I removed to put on another car but haven't done it yet.how about this one . can bolt on or weld right ?
Yes, absolutely. HOWEVER ... if you have the ability to weld, why bother buying these when you can use square tube for a FRACTION of the cost. Instead of those "bolt on" front brackets just butt weld to the crossmember - which you'd basically be doing anyway. And the back is easy-peasy as well. Save your $$ for another project/can you weld these ?
