Rubber brake hose on rear axle-washer?
Grizzlys Garage
8:58 PM
Southern Illinois
The rubber brake hose on the rear axle, does it get a copper (or other) washer where it threads into the T block on the rear end housing?
'69 Charger...
Not Mopar specific, but it’s not a “regular” washer. It should be soft copper with a little larger hole. The hose “should” have come with it
Thanks, it figures that it should have come with the hose. That's the problem with buying parts, and installing them months or years later. I can't really go back and complain now, especially since I'm not 100% sure where I bought it.
I'll have to try and find something that will work.
Are the washers used in diesel injectors, and motorcycle brakes similar? I keep a supply of them. They can corrode over time, but it takes while.
I am assuming you have an 8 3/4. If so, then the parts manuals show the same part for 67 and 69.
Thanks to everyone that responded.
It does have that flare thing that was mentioned.
I'm just going to stuff it in there without a washer and see what happens.
What will happen is a nice leak free joint, just like the factory intended. This is assuming that the hose is the correct one and is made properly.
They DO call for Copper Washers —- and while the inverted flare is supposed to seat and seal 100 % —- why not have the safety and security of the Copper Crush Washers seal the block of the splitter to the face of the brake hose….
For years , they used to come with the brake hose automatically…. While illustrated , they have not come with the brake hoses for the last 25 years….
While I pay $ 32.00 for a box of 100 —- and they are half the thickness of yesteryear —- I give out two (2) FREE with the purchase of all of my brake hoses…..
With all due respect, I disagree. My parts books do not list a washer for that application. They list one for the 9 1/4" dana used in some C bodies, but they used a different tee block. Even if you disregard the parts books, why would the factory use both together. Copper washers work just fine by themselves as do inverted flares. Nowhere else in the brake system do they use them both together, so why there? As a side note, the washer would have to be approx. 1/8" thick to fill up the space.
You can disagree all you want , and when you have seepage , you will have real wet tears…..
You do what you want , I am sure not going to force you to do it the right way……
We sure do not want to stand in the way of you peddling your washers.
I have never seen one used there.
^^^ I pay for them and give them away for FREE ^^^
Is there a problem ????????
R J Squirrel —- can you do the math ??????
