Jim Lusk and his sons are in your area. They are good ppl. Jim is on FABO. Kim
Thanks for the pointers. I'll try to find Lusk. I don't know what FABO is, though.
Well this is FBBO as in forbbodiesonly. FABO is forabodiesonly. KimThanks for the pointers. I'll try to find Lusk. I don't know what FABO is, though.
Got it.Well this is FBBO as in forbbodiesonly. FABO is forabodiesonly. Kim
many of my cars are converter to roller cams, and oil changes on them still are not cheap when using synthetic oil.This just made me think to factor in cost of high zddp oil as a factor when choosing flat tappet or roller. $100 oil changes get old pretty fast.
It’s not the only factor, but it is A factor.How many oil change would it take you to recover the $$$ spent on the roller set up?
Very true, but it's the one you mentioned and I was curious. I would also like to switch to a roller setup.It’s not the only factor, but it is A factor.
Someone previously reminded me that I do not have a dial indicator.Big block Mopars are pretty straightforward to rebuild but you’ll need to get your hands on some specialized tools to do the job correctly. Top of the list is a decent torque wrench. You will also need a ring compressor, feeler gauges and a dial indicator is useful for checking crank end play, finding TDC and to degree in the cam. Over the years I’ve accumulated a drawer full of tools used almost exclusively for engine building, although I have gotten by with much less…
