Fuel Line Flare
50 Coupe
11:00 AM
Indianapolis
I'm making my fuel lines. Mostly hard line [5/16] but will use fuel hose where necessary.
Quick question. What flare should I use on the hard line where it joins the hose? No flare, double flare, bubble flare??
a little bubble.. that's just me though.. some people don't flare but i'm crazy paranoid about random gas spraying around, every bit helps :)
Yep, a little bubble flare would be perfect for mating to rubber hose with a clamp. For steel lines, a single flare would be ok. Brake line you buy pre flared will be double flare of course. If you are using bulk steel line, you could use either flare.
* if you make your own lines.. get nickle copper... OMFG..... i didn't listen and when i finally did it is soooo insanely easy to work with compared to steel...
I like to use a bubble flare. With the low pressures involved it’s probably not critical but it does give me some peace of mind.
But it looks sexy and I would like to know how to do it. It does looks more functional than just slipping it over the tube.
I have a regular flaring tool. What should I be looking for?
For the one in the pic i posted way up top which technically isn't a bubble flare.. i just use my flare tool and start the flare and stop when it just gets where i want instead of following through...
