Offseason Build Thread - Project 68 Charger Race Car
KohrtRacing
12:08 PM
Colorado
Hi B-Body friends,
I was asked by some friends to post a running thread updating as the offseason goes on my Charger so I figured I’d share it here if that’s alright. It’s a drag car, 68 Charger that’s undergoing a serious transformation this offseason that includes body work and paint, roll cage and weight loss, along with a potential 440. Currently has a 383 / 727.
Will be updating this thread as projects are completed and progress continues. Thanks for following along! Social media updates by searching: Kohrt Racing
Hi B-Body friends,
Body work and paint is the first project. Body work is extensive as it has hail damage from sitting outside for 30 years. The original red has been primer’ed over.
Plan is to use Summit Racings epoxy primer after getting it to bare metal in most places. Then fill before sealing and going with a single stage with a clear over it. My plan is to paint with a $1000 budget. Currently I’m at $600 with everything except for paint. For guns, I plan to use TCP global’s kit including a 1.4mm and 1.7mm. It also comes with a handy 1.0mm for the jambs which I do plan to paint.
I will also paint the inside of the doors, hood, trunk and possibly the engine bay as well, but not the interior. Which is getting a total rework in its own way.
Metal work begins shortly with not only several patches but a 10-pt roll cage!
How serious are you about racing? Full season points type thing? Don't be afraid to talk to people about sponsoring a paint job maybe.
Or a rollbar...
Hi B-Body friends,
Shelving paint and body for some metal work, first up is the roll cage.
Going with a 10pt and an 8.50 cert. swing door bars. I find approaching big projects with three focus’s to always lean on are solid foundational thoughts. For the cage I wanted safety, premium visibility for racing and easy in and out.
The main hoop was first up and thankfully, nailed the bends on the first stick. Chromoly 1 5/8th is actually fairly cheap but I have no interest wasting tubing. With a good foundation to build off, the dash runners are next.
The drivers side is bent and tacked in. Invisible from the side of the vehicle, the bar is neat and unobtrusive. Tucked in to the headliner cavity, the bar provides protection without distraction.
Ordering welds from top to bottom is generally the most appropriate way around it. Cutting holes in the floor to drop the cage through is a nifty tip to weld the top of the bars before bringing it back up and finishing the welds. I plan to weld 100% and use gussets. Swinging door bars and more work on the passenger side dash bar is next!
Hi B-Body friends,
Latest update for the roll cage. I’ve completed both dash runners, tucking them in as close as possible to the pillars. I’m fairly happy with these and after seeing a ton of race cars cages, I’d say these run equally if not better fitment then many of what I’m seeing.
Next up is door bars with a swing out on the drivers side. Harder than I thought with the spacing on the clevis’s, NHRA rules stipulate the points on both ends must be within 8-inches. Setting them at 6 puts them in good positions to pivot but stay hidden. Slight 5-degree bend gets the around the door mechanism and the window roller while keeping the bar running upward between the shoulder and elbow, satisfying another NHRA rule.
Back bars and two D bars are still needed to complete the cabin work. More bending and more touching up! Getting close to a full day of zipping it all together!
Thanks for mentioning the doors. I'll need to put those on when I do my cage.
Hi B-Body friends,
Busy day as more progress continues on the roll cage. Put a slight curve with a roller on the windshield bar as it adds visibility, and tuck it up to the roof nicely following the natural body line of the car. Infinitely safer and just looks better. Will add tabs to utilize my ARC ignition box. Hanging it above, just like the pro stock cars ;)
Also finished up the D bars, and fabricated plates to close off platforms towards the bottom by the foot box for better strength and appearance
Passenger door bar and bar bars are next. Still debating if I should put an X in or not. If anyone has pics of their rear bars, would love to see!
Hi B-Body friends,
Getting real close to weld up time. The passenger door bar is in. Quick 5-degree bend near the middle just under the handle allows for both my handle to open freely as well as my custom jr dragster rod handle that operates the window.
Fitting up the final fabrication pieces which are the back two bars. These are universally the most flexible bars NHRA rulebook wise for the cert I’m going for. As long as you follow sizing of the tube, you could do just about anything and everything but the more you do the more work and weight added.
I thought about an X, possibly an extra bar in the middle for additional strength and a mounting point for a laser cut plate with logos. Visibility for racing, driving is a priority but honestly its strongest form for safety is also straight. 6”x6” plates of 1/8th like inside the cabin with the usual chromoly 1 5/8th .083 wall does the trick and we’re ready to mock up with tacks.
A amperage control slider at the torch accessory is in the mail and should arrive next week. Just in time to be ready to zip it all together from top, down!
Nice job on that cage. I see a lot of them done by lazy fabricators and they’re horrible. I like to tuck everything, especially A pillar bars so they don’t block your vision.
Very nice. Safety was obviously the top priority but it was important that visibility was not effected for obvious reasons. Some of the cages out there, oof man. They’re bad.
Will be gusseting everything but I do plan on some tabs as well for race car related stuff. Like the tuck on those pillars. That’s solid.
