Vibration on Highway at 60+
RyanB89
11:59 AM
Plymouth, MA
Hey guys, I’ve been through all the similar threads and can’t seem to figure this issue out. Thought a new personalized one might be my best bet.
69 Coronet R/T 440/727. 8 3/4 Rear with 3.55 Sure Grip. Have a bad vibration at 60+ on the highway. Can also simulate the vibration somewhat with the car on the lift and bringing it up to speed.
Had driveshaft balanced and new ujoints installed everything seems tight. While I had the driveshaft out, installed new bushing, rear seal and trans mount. Driveline angles all checkout on the Tremec app.
Vibration appears to come from the transmission. Particularly the tail shaft area. Inspected the flex plate, can’t see any cracks. Tried different wheels/tires and same issue.
What am I missing? Drives great on the backroads, but highway speed vibrates like crazy. Feel it particularly in the center console area, steering wheel is smooth. Rear view mirror shakes like crazy, can’t tell what kind of cars are behind me.
Thanks in advance!
Give this a read ??
Worn slip yoke?
Scroll down theres used whole driveshafts for 200.....maybe try a whole different unit just to see if you are headed in the right direction?
long shot, but you could listen to the tail shaft with a stethoscope. The diff too. harmonics can travel through things
Give this a read ??
I read through that. I could try replacing the tailshaft bearing and the rear end seal he mentioned. I believe my angles are correct but will triple check!
How much slip yoke is showing with the car sitting on all fours?
Originally it was bottomed out completely for some reason. We removed the driveshaft, shortened by 1” and reinstalled with new u joints. It now sits about 1” from bottoming out and has room for movement.
I may have missed someone else suggesting this, but I would check the rear shaft bearing. Not hard to do with it in the car.
When you had the driveshaft balanced did they check runout? My rear view mirror vibrated really bad at 70mph, looking at it kind of made me dizzy. After double and triple checking driveline angles I pulled the driveshaft and brought it to Proven Force to check the balance. The balance was good but the total indicator runout was way out of spec. IIRC max allowable runout is .010. Somewhere along the way the tube was dented, I know the previous owner had similar issues because he shattered the tail housing at speed street racing one night. Proven Force replaced the tube, rear yoke and u-joints, it’s been smooth as silk ever since…
Replaced the mount with a new rubber one. Do you think going with a harder poly mount might be better?
It could be as it could hold up alot better to the abuse its put through, where oil would breakdown a factory mount much quicker.
The tail-shaft bearing seems like a logical place to look. So does engine balance. Was the engine precision balanced or simply put together with off-the-shelf parts?
Thank you all for your great responses!
Yesterday we ended up swapping the driveshaft from my father’s 71 RR. Back on the highway and the vibration was still there, but did seem to improve it some. It vibrated from 63-68 MPH but seemed to get better at 70 and above. If at 70 and putting into neutral and letting it coast to 65, it doesn’t vibrate. However if I raise the RPMs in neutral in that speed range, it does vibrate.
I’ve ordered the rear bearing and will give that a shot next. I’ve also seen some folks with the tail shaft weight dampener installed. Do you think it’s worth throwing one of those on as well?
Thanks again and will let you guys know how it goes!
Before you try a new right rear axle bearing just do a simple end play check.
