Vibration on Highway at 60+
RyanB89
8:04 PM
Plymouth, MA
Hey guys, I’ve been through all the similar threads and can’t seem to figure this issue out. Thought a new personalized one might be my best bet.
69 Coronet R/T 440/727. 8 3/4 Rear with 3.55 Sure Grip. Have a bad vibration at 60+ on the highway. Can also simulate the vibration somewhat with the car on the lift and bringing it up to speed.
Had driveshaft balanced and new ujoints installed everything seems tight. While I had the driveshaft out, installed new bushing, rear seal and trans mount. Driveline angles all checkout on the Tremec app.
Vibration appears to come from the transmission. Particularly the tail shaft area. Inspected the flex plate, can’t see any cracks. Tried different wheels/tires and same issue.
What am I missing? Drives great on the backroads, but highway speed vibrates like crazy. Feel it particularly in the center console area, steering wheel is smooth. Rear view mirror shakes like crazy, can’t tell what kind of cars are behind me.
Thanks in advance!
Give this a read ??
Worn slip yoke?
Scroll down theres used whole driveshafts for 200.....maybe try a whole different unit just to see if you are headed in the right direction?
long shot, but you could listen to the tail shaft with a stethoscope. The diff too. harmonics can travel through things
Give this a read ??
I read through that. I could try replacing the tailshaft bearing and the rear end seal he mentioned. I believe my angles are correct but will triple check!
How much slip yoke is showing with the car sitting on all fours?
Originally it was bottomed out completely for some reason. We removed the driveshaft, shortened by 1” and reinstalled with new u joints. It now sits about 1” from bottoming out and has room for movement.
I may have missed someone else suggesting this, but I would check the rear shaft bearing. Not hard to do with it in the car.
When you had the driveshaft balanced did they check runout? My rear view mirror vibrated really bad at 70mph, looking at it kind of made me dizzy. After double and triple checking driveline angles I pulled the driveshaft and brought it to Proven Force to check the balance. The balance was good but the total indicator runout was way out of spec. IIRC max allowable runout is .010. Somewhere along the way the tube was dented, I know the previous owner had similar issues because he shattered the tail housing at speed street racing one night. Proven Force replaced the tube, rear yoke and u-joints, it’s been smooth as silk ever since…
Replaced the mount with a new rubber one. Do you think going with a harder poly mount might be better?
It could be as it could hold up alot better to the abuse its put through, where oil would breakdown a factory mount much quicker.
Went thru this about a month ago on my 1969 r/t. Turned out to be the axle end play was too tight.
