Ten Rules for Maximum Cooling
If you need anti freeze because of your climate, you add just enough percentage to prevent the coolant from freezing. AF reduces heat transfer ability to the coolant, so use enough but no more...
I've read of people using distilled water or some other treated water in their cooling system.
I never have done this in any car or truck that I have had. I have seen no drawbacks from it either. Is this supposed to be more important in areas with lower quality water?
Yes. Any minerals or dirt in a heat exchanger system will eventually "plate out" - deposit themselves on the tubes of the radiator. This is a slow process in some cases, but it will ALWAYS happen eventually. Distilled water is "pure," no minerals or dirt in it. Well water is chocked full of minerals. Municipal water is often full of calcium and lime from the treatment process.
I have two rules of thumb for Mopar cooling problems -
1. Your radiator is dirtier than you think on the inside. The little bit you see in the cap opening may not tell the story.
2. You need more flow. Factory Mopar thermostats in the 60's and early 70's, the big cup type, had an opening port around 1 7/16" diameter, vs 1 1/8 for a typical Stant thermostat.
Yep. Hard water deposits clog tubes.
I routinely keep 1-2 gallons of distilled water in the garage for topping off the radiators on my cars.
Another tactic for engine cooling at idle is properly advanced initial timing. Most modified engines prefer additional timing, without creating detonation at load.
When you buy corrosion inhibitor concentrate, it is usually recommended to use de-mineralised water with it....not distilled water. I guess the DM water has had the minerals removed that might cause corrosion or interfere with the corrosion inhibitor chemistry..
I use Reverse Osmosis water. I can usually find it at the grocery store.
I think RO water is a "lesser" De-Mineralized Water.
Careful is an an AI take on this...
AI Overview
Reverse osmosis (RO) water is treated by a semipermeable membrane to remove most dissolved solids, while demineralized (DI) water has its mineral ions removed through an ion-exchange process. RO water is great for drinking and household use because it retains some beneficial minerals, while DI water is a higher-purity product, removing nearly all ions, making it ideal for labs and industrial applications where mineral absence is critical. The primary difference is the level of purity, with DI water being more pure than RO water.
Ten Commandments For Maximum Cooling
1. Make room for an adequate cooling system in the design of your engine compartment.
First things first. When planning your performance vehicle, remember that you're building it to drive, not to sit and steam. Plan adequate space for the cooling system including the radiator, fan, shroud, overflow tank, and mounting brackets. Talk with one of our specialists to help you build the system for your vehicle, engine size, and driving habits. Consider the investment compared to the total cost of the car.
2. Use an electric fan.
Only choose a mechanical fan over an electric fan if it's your farm tractor. An electric fan is preferred because when you need a fan the most (at idle or cruising speeds) an electric fan is delivering maximum air independent of engine RPMs. Fans that move 2000-2300 CFM's are worth the investment. Preference should be given to a "pull" vs. a "push" fan. Mounted on the engine side of the radiator, a pull fan does not interfere with airflow at highway speeds. All shrouded fans should be on the engine side of the radiator.
3. Always use the right shroud with your fan.
Fans move air through the radiator assisting in cooling the engine. A fan without a shroud is better than no fan. But, consider this - at idle or cruising speeds, you need the entire cooling system working at its optimum. An unshrouded fan is moving air through only the portion of the radiator equal to the surface area of the fan. For example, on a '32 Ford, the area of a 15.50" fan is about 189 sq. in.; the core of the radiator is approximately 371 sq. in. This means that almost 49% of the unshrouded radiator is not receiving any benefits from the fan. Shrouding your radiator lets the fan pull air through the entire core
4. Consider airflow and how a radiator uses it to cool.
Without adequate airflow, a radiator is just a reservoir for hot water. Coolant transfers heat to the tubes; the tubes transfer heat to the fins; air moving through the fins dissipates the heat from the radiator. You need sufficient openings to the radiator that channel adequate air to the entire surface of the radiator. You must have a radiator design that allows the air to pass effectively through the radiator (wider and taller is better than thicker). You must consider how the heat will be evacuated from the engine compartment.
5. Use the proper water pump pulley ratio.
To obtain the maximum operating efficiency rate for your water pump at highway speeds, you should overdrive the pump by 30-35%. Most aftermarket pulleys are a 1:1 ratio. For a 30-35% overdrive, the crank pulley should be approximately 7 7/8" and the water pump pulley approximately 5 3/4". This overdrive provides proper coolant flow from the engine and through the radiator.
6. The pressure cap matters.
The higher-rated the pressure cap, the hotter the water has to get to boil. One pound of pressure raises the boiling temperature by 3°F. A 16-pound cap raises the boiling point to 268°F. If your engine is designed to run at 200°F, a 14-16-pound cap should be sufficient. Running a higher pressure cap to prevent boil over is putting a band-aid on another problem that needs to be fixed. Higher operating pressure places additional stress on the entire engine system and increases the potential of hoses bursting and possible injury.
7. Understand the operating temperatures of today's modern engines.
All engines have "normal" operating temperatures. Running engine temperatures well above or below recommended temperatures could cause damage. Most of today's engines operate in the 180°-210°F range. Pollution laws, new oil blends and higher combustion gasoline have forced engine design changes that have increased operating temperatures over the past decade. Consider your engine's normal operating temperatures when selecting your radiator's cooling capacity.
8. Always use a thermostat.
The thermostat controls engine coolant temperature. It stops the flow of coolant through the radiator until the coolant reaches the thermostat's preset temperature. Operating your engine within its temperature parameters reduces wear, helps control emissions and turns any moisture in the crankcase to steam where it is removed by the PCV system. Selecting the right thermostat for your engine's operating temperature range means better performance and longer life.
9. Protect your system with the recommended coolant.
It is essential to use a premium coolant that protects the radiator, other metal parts, and seals. Today's coolants are a scientific blend that normally includes water wetter and corrosion inhibitors. The use of a coolant that contains no silicate is recommended. Silicate is an abrasive and can cause gel formation and water pump failure. A 50/50 mix of coolant and distilled water provides the best overall cooling efficiency. Proper maintenance (regular flushing and changing of coolant) will extend the life of your system.
10. Spend your money wisely.
If you are having cooling problems, begin by looking at the least expensive fixes first. 1) Add an electric fan. 2) Shroud your fan. 3) Check your belts and hoses. Slipping belts or collapsed hoses mean trouble. 4) Check your radiator cap. 5) Flush and refill with premium coolant. 6) Use the proper thermostat. 7) Clean the radiator of foreign materials. 8) Overdrive the water pump 20-30%. 9) Check your water pump. Should cooling problems persist, it may be time for a new performance radiator from Griffin. Call the Griffin Customer Service Department at 1-800-722-3723 for assistance in selecting the correct radiator for your requirements.
** WARNING: Improper wiring can cause electrolysis and destroy the radiator. Please make sure radiator is not used as a ground. **
Thanks for starting the conversation!
I never thought about what water I used in my radiators in california. Here in AZ the well water is SO bad, I buy drinking water 45 gallons at a time.
I'm thinking it may be time to flush a couple cooling systems and put some good water and water wetter in.(dragstrips do NOT like antifreeze!) . Freezing doesn't seem to be much of a problem here.
Preventative measure. I don't have any cooling problems. I've got the very biggest radiators that will fit between the frame rails. And I don't drive them much when it's 115° .
Don't throw away the "spring" inside the bottom hose! Reuse it if the new hose doesn't have one!
I’ve always thought oil capacity has an effect on cooling. I drive a Camry as a daily driver. It’s a small 4 cylinder and yet it holds the same amount of engine oil as my 68 charger. Always wondered why all the auto manufacturers ran so little oil capacity vs the engine sizes back in the day compared to today’s engines? Perhaps they were just limited on capacity based on the design of the chassis and engines?
Not that long ago some high output marine 4 stroke engines had alarmingly small oil pans, it was to save weight, but they probably figured out that they needed more oil capacity for overall better performance. Today's engines have closer to 6 or more quarts, rather than the four, they used to have.
A bigger oil pan is one of the first mods I do to any hi perf engine I build. I try for seven quart capacity at a minimum. Don't always run them full, however.
Giant road race pans are preferred, if they don't interfere with headers or chassis.
Also not all high volumes pumps are high volume.
While putting a hemi in a RR about 12 yrs ago I ordered a high volume water pump to install and even though it had the flat plate added to the front side of the blades you couldn't see how well the back side of the blades fit to the bevel inside the housing.
I could of used some play dough to check clearance but I had plenty of spare housings and picked a mid 70's left feed housing to cut a window to quick check any pump.
I was disappointed in my new high volume pump and the FlowKooler of the late 90's. I ended up extending the blades on the high volume as it was new and easier to fix than the curved blades of the FlowKooler.
Haven't gone in to see how well the blades are hanging in there sinse the build but the temp gauge seems to say they're still ok. It has a Glen Gray with Max Cool core and the Mercedes/Monster fan with v3 controller.
The high volume had .191 thou clearance to the housing. The FlowKooler was a little better.
Some one in this thread mentioned a lower hose spring, I found a SS spring from a phord site for the lower hose.
Fan runs after shut off for a litte while on the hemi, while my Dart 330 has the mecedes fan also and a remote water pump for flow with the fan after shutoff.
The 475 hemi cools great, the Darts 499 needs a bigger radiator, the 22" is a little small and the fan works harder of which I figured it would but wanted to see if the fan would take up the slack.
I read where it is recommended that there be a minimum of 1” between fan and radiator? On chasing my cooling issue I noticed that I not only do not have a 1” minimum I also have a canted radiator. Fan to fin gap on one side is only about 5/16” while about 3/4” on the other side.. The slant is also noticeable between the top tank and the support frame of the car. Would this be a possible cause of running hot?
No. Have never heard of the fan to core deal. Lots of cars have various distances. 6cyl vs V8’s for instance. And new cars with electric fans are cluster then 1”.
That amount of slant has no impact.
The fan shroud opening to fan diameter should be 10% difference.
You have a shroud, right?
You have an aftermarket radiator? One of the aluminum ones?
No shroud. The car didnt come with one from the factory. I think only cars with a/c had shrouds in 62..
My radiator is for a 68’ small block while the car is a 62 Bn.
