Cornpatch MO
Today. I found that if you need a longer throttle cable for a 64 Dodge, A slant six cable works very well---HOWEVER, don't use any heat on t he inner cable when changing to a cable end that will work. It will take the stiffness out of the cable and allow it to bend easily. You know how I found that out!
If you mount the battery in the trunk, and run the ground cable to the rear subframe, you will have a ground up in the engine bay. BUT, not enough ground to make the starter motor turn the engine . By running another ground cable from the front sub-frame to the engine or tranny, That will make her spin! You know how I found that out, after charging the battery, adding jumper cables, and worrying that the starter was bad...............................MO
