Tire presure
thunderbolt
8:09 PM
ontario
Just looking for opinions , 1970 plymouth b body with a hemi 255/60 /15 on the front and 275/60/15 on the rear what do you people run for tire pressure with that combination , just looking for opinions
But some could use more TLAR than others.....
Check the tire for max pressure specs.. I like 35psi, but BFG t/a is 35 max so I run 30... the Mickey Thompson sportsman s/t are 44psi max so I run my 35 ....
Wheel width also needs to be taken into account. A 275-60 on 7" rim will probably need a less PSI than if it were mounted on a 9" rim....
What ever gets the most tread contact with out compromising sidewalks.
Presume radials, 35 on front, vary the rears depending on what you're doing. Max traction rear maybe 22-20. Normal 35.
