BeepBeepRR
Ok guys.. I purchased a rusted out old 66 Belle. I started ordering sheet metal. 2 quarters and 2 trunk extensions. Well, they arrived today and I did a test fit on the quarter panels. The front body line matches up perfect. The rear part of it is way off by an inch and a quarter. I dont want to mention the company name yet I want to give them a chance to correct the problem. Being as though not many places make the entire lower quarter like I needed. Anyhow here is the picture of the 2 lines.. The line they made and the actual line it needs to be with tape. The portion of the tape facing the wheel opening is the side that is correct. Both sides are the same. 1 1/4 off.. Sadly I need all the way up to the edge of the sheet metal to fix the rust issues. Or I would just cut off what I need to make it work.
