VitaminCRR
I am putting a Dr.Diff disc conversion kit on my 69 Roadrunner and I'm at the point where the distribution block can be installed. Do I remove the lines from the block first and then remove the block from the frame? Or vicey versey? Also, do you access the d-block from the top or the bottom? Thoughts?
