Jordan Yale
Hey guys,
I have a new set of fully ported Indy 440-1 345cc heads and fully ported Indy 440-3X intake done by Wilson manifolds as well a few other unused quality components.
I want to set up either a 400 or 440 stroker, ideally between 505 -540 c.i. that would be used 70% on the street and 30% on the strip. Not going to use it for cross-country road trips, just casual cruising and the track. With a good block, billet main caps, and quality bolts, I’m sure I can get longevity out of a factory block for this use.
I want to be able to push a heavy B-body down the track with respectable time and I don’t necessarily want to spend money on an aftermarket block (unless someone has one at the right price). What combinations have you guys used that have worked that are similar? Thanks!
