Need one for a mock up that I will grind and sand to make fit. So stripped threads, crack, or corrosion will work fine. Don't need the float or small parts, just the bowl.
if you get stuck, it's the same a front/rear six pack bowl (ask me how I know) and you can buy them new (if you must) from Chicago Carburetors. "Dimensionally" all the v-bowls are the same, front or rear, unless you need to mock up & clearance something to do with which side the fuel line comes in on and/or an accelerator pump
Thanks BP,
I have an outboard 6 Pack carb. It's a good carb, or I would experiment on it. I'd buy a whole 6 Pack outboard carb that is not rebuildable if I could.
