Wiper arms are not available for my car
Gunner1
12:06 AM
LA Cal
Why can I buy lots of wiper arms for a 65 but my 63 polara are no longer being made. Are they really that much different. Anyone have a working part number. I’m about ready to start hitting the boneyards for some used ones.
Thanks
Bob
Perhaps you can convert to 65s? Pivots and arms.
Mike
If you can find adapters that bolt on to the 63 pivots that would be your easiest fix.
Then you could use the newer wiper arms.
I found them on a 63 Dodge Polara that I parted out.
Ed
Or you could start a wanted thread for some here on FBBO. Are yours missing or not in good shape?
Are the pivots of the same design where you could simply install a set of 65 pivots?
I understand they are different and require the nut to bolt them down...seems I remember they are also smaller in diameter and taper...Just seems it would be easier to swap out the pivots and then use the 65 arms...
I'm not a 63 guy but am pretty familiar with the 65's...
If 63 is the same as 62 I might have a used pair.
Can you get wiper refills rubber blade part or do you have to get the whole thing for a 63 ? Thanks
There will be shopping available in Vegas next month and more in Van Nuys in April if you don't score. Also Soledad Performance in Lemon Grove. 619-697-1136. The owner, Kris Cane, passed away last year. His wife Debbie has taken over on moving his inventory of Mopar stuff. He specialized in early b-bodies. Another possibility.
If you guys ever need early B parts, give Clay & Rosie a call at 636-257-4669 or 314-954-0815. They have never failed at getting hard to find parts for my savoy and at reasonable prices.
Chuck (snook)
Clay and Rosie are good friends of mine, if you need early stuff or any stuff give them a ring or let me know... Some of the finest and nicest folks you can deal with!
I got a great set from Part Stalker
