Paul_G
- 1:47 AM
- Dec 24, 2013
- Surprise, Arizona
After the install of the air fuel ratio gauge I found the carb tune was way off. Too rich at idle, mid 11's, to rich at cruise, low 12's, and stupid lean when given the beans, mid to high 15's. How the carb is built is a puzzle. It does not have a Holley list number. Looks to be a custom built carb. Best guess is it's a Holley 950. Mechanical secondary's, no choke.
The engine it is on, 528ci Hemi with an F1 Procharger. So a custom built blow through carb is in order. But why is it built like this? The build explains how it performs.
Jets, Pri 72/ Sec 86, 31 squirters front and rear.
The power valves on both sides have the vacuum passages blocked in the base plate. They were tapped for a set screw and sealed with epoxy. So the power valves were not working. The bowl vents are extended in to the charge tube, they did good work on that. The metering blocks have been drilled and tapped for adjusting the idle mixture in the idle feed circuit. This work had to be done by someone who knows carbs. A back yard hack does not do these kinds of things to a carb.
My plan is to leave the jetting as is for now. I opened the vacuum passage to the front power valve and put a 4.5 PV in it. The rear vacuum passage stayed closed for this, https://simplestage.shop/products/brpb-boost-referenced-power-valve , an adjustable boost referenced power valve.
With working power valves the carb should be pretty rich with that jetting. Safer to start there.
What do you guys think?
