Hey guys...
No, I have not abandoned, sold or parted out this car despite how it appears....
I've tinkered a bit here and there. August last year I tried installing a power booster from a mid 70s Dart, something similar to what I used before on the red Charger/Ginger. The idle vacuum on this engine is not that great, maybe 11" ? I ended up putting the manual master cylinder back in. I contemplated a swap to a wider axle to utilize a set of wheels with deep backspacing, an endeavor that made no sense in retrospect. I have this tendency to try to make do with what I have at hand and the set of 16" steel wheels would have given me a cool NASCAR vibe that I like.
Later in the year I fiddled around with adding rear shoulder belts and with the help of fellow FBBO member
@CoronetDarter , we made some interesting changes that didn't cost much to do.
I have a few other projects going that should provide some cash to sink into this car and options are pretty open.
I will keep this car an automatic but will want some type of overdrive. the three options that I'm aware of is a 518 with a JW bellhousing, a Gear Vendors or a Silver Sport Overdrives A41 setup. The costs incrementally rise from one to the other.
I like the idea of staying with a big block but adding stroke to this engine. I have a 440 that is cut down to fit the B series block. I have the bearings for that too. I'd need a set of pistons and rings and of course, balancing. Is that expense worth only going from 383/388 to 431 cubes? Does it make more sense to go with The 440 Source for a 4.15 stroke? Part of me thinks that I don't necessarily think every big block needs to be almost 500 cubic inches. The red car is a 440/495 already, would I be okay with Jigsaw being "only" 431 cubes? I think that I might.
The suspension and brakes on this car are solid. I see no reason to make changes, even the rear drum brakes can stay. They are reliable and they work great. Mechanically, the car is well sorted. I would just like it to be a bit faster, get a bit better freeway mileage, be easier on me for road trips. As far as the appearance aspect...
It has been a few years since I have done a full body and paint job. I'd like to think that I still can do it well. I did the work on this car.....
I guess I'll find out if I ever get to it!
