02 sensor location?
431Bird
2:29 AM
Iowa
Hey, got a quick question. I went e 85 and bought dual 02 sensor's. Problem is I have the evac where probably the 02 sensors should go. What should i do? Do i take the evac off and try to run valve cover breathers? Or should i take the header extensions and put the evac there and put the 02 sensors where the evac pipes are on the headers? Im guessing option 2 is probably the best, but could be alot more work i guess...lol
Thanks!
The o2's should be a few inches after the collector and before any H or X pipe, but with your evac setup you'd probably end up soaking the sensors in oil ! Can you squeeze them both right next to each other after the collector ?
65-440 makes a good point. How about locating the O2 sensors an inch upstream of the blow-by evac system?
That was my main concern was soaking the sensors with oil..I didn't know if I could just get rid of the evac..and try just breathers. ..but probably bad idea
