- 10:48 AM
- Jan 16, 2011
- NorCal Sierras
Haven't seen this in a while coming along nicely
nice quality detailed work too
It has a groove but I'm guessing to utilize it you must be able to insert the first part of the fitting through the support brackets hole? It's to small so I guess I just need to drill it up a tad..?As in the hose end doesn't have a groove for a clip?
Mike
Must be the wrong thing to do-it's far to easy! Dropped spindles=your car-your choice. You can reverse the change with nuts and bolts.It has a groove but I'm guessing to utilize it you must be able to insert the first part of the fitting through the support brackets hole? It's to small so I guess I just need to drill it up a tad..?
Looking good! We are all getting excited!@493 Mike
Way to easy!
Well, atleast it's done, rear axle completed. Waiting on u-bolts and blocks to arrive. Cleaned and painted the hangers with cast iron paint.
View attachment 996653 View attachment 996654 View attachment 996655
Have we been introduced to the dark Charger?My steering rod stuff arrived. I didn't want to pay as much as the Hotchkis bump steer kit let alone wait for it so I sourced metric stuff locally instead.
Got myself a lifting plate for the Hemi also.
Out with the old, in with the new. Cleaned up the spindles and hubs, new bearings and seals in.
Getting close to putting the front end together.
View attachment 1000485 View attachment 1000486 View attachment 1000487 View attachment 1000488
Mentioned in the first post only. Matching number -69, 440 RT/SE, 727, 8 3/4. A4 silver originally. Mechanically restored, new interior, unmolested engine bay and trunk but needs a new paint job. We decided to wrap it in the meantime. Might repaint it to A4 sometime in the future when my -68 is finished. It's a good driver without any rust.Have we been introduced to the dark Charger?
Mike
Cool that your dad is still around and a car guy!Mentioned in the first post only. Matching number -69, 440 RT/SE, 727, 8 3/4. A4 silver originally. Mechanically restored, new interior, unmolested engine bay and trunk but needs a new paint job. We decided to wrap it in the meantime. Might repaint it to A4 sometime in the future when my -68 is finished. It's a good driver without any rust.
Belongs to my father, we traded. He got the black Charger and I got a nice -68 body and the Ray Barton Hemi
Am I the only one that doesn't like the fuel pump that close to the u-joint?Big milestone today, installed the dana and took it out of the rotisserie.
Screwed up when I measured clearance around the fuel pump. But I think I can save it by replacing the straight fittings with elbows.
Got the wheels close to the lip so that was a success atleast.
Now it's finally time to marry the k-member to the old elephant..
View attachment 999411 View attachment 999412 View attachment 999413 View attachment 999414 View attachment 999415 View attachment 999416 View attachment 999417 View attachment 999418
It's behind the axle. Woops, I was mistaken it is in front. You should write this down, in case I ever make another mistake!Am I the only one that doesn't like the fuel pump that close to the u-joint?
