my center section seal is much thinner than the one you show,Also.. @moparjohnny .. don't forget to trim your center section to hood seal out to match the OE or you'll crack your box riveting it on!!
thanks i understand it now,my center section seal is thinner than the one you show,i ordered from loretta fillmore looks thinner. but i will trim a little off anyway.thanksAlso.. @moparjohnny .. don't forget to trim your center section to hood seal out to match the OE or you'll crack your box riveting it on!!
I think mine came from the same place.. she is also Detroit Muscle if I'm not mistaken. The OE is formed to about 1/2 thickness to clear the hood web detail. If you don't trim it you put extra stress on that side and may break your rivet tabs off the box. Here's another shot of the OE and the new.my center section seal is much thinner than the one you show,
thanks i understand it now,my center section seal is thinner than the one you show,i ordered from loretta fillmore looks thinner. thanks
Had a real “pucker” when tightening that screw on the glass I bet?Latch hardware. Outside chrome "nut", long wall rubber washer, thin rubber and screw.
Outer "nut" and rubber washer in place.
Rubber, latch and screw from the inside.
Top of the hinge channel sealed with some Butyl.
Couldn't find a spec but I grabbed this foam a while back as it looked similar in size to pictures of the OE I had when I was taking my interior out. Unfortunately the paint shop toasted all that foam and I never got to see it to be 100% sure.
Foam is 7/16 thick x 3/4 wide. It goes from the bottom of the hinge channel, over the top and around to just past the latch plate. Ready to install to car.
Passenger side coming apart ready to rebuild.
This side the hinge material wasn't as busted up and I noted that on the inside it is trimmed back to about the same width as the rubber seal for a better mating I presume. This shot is the top.
This is the bottom end showing how it is trimmed back.
View attachment 741486 View attachment 741487 View attachment 741488 View attachment 741489 View attachment 741490 View attachment 741491 View attachment 741492 View attachment 741493 View attachment 741494
I could see them reflecting off the garage door!!! This switch is so much smoother than the repair plate I'd put in there that failed. Brake lights work correctly tooooo !!Wayne,you lazy b——-, you didn’t even walk to the rear to make sure the rears were working! Well done,Jeff.
Wasted the entire morning trying to find some open cell foam. Nobody sells it anymore.. not even in White. I went to EVERY hardware and lumber yard in town as well as CTC. Thankfully I had a package buried in my stash, but a size smaller than I really wanted. I would have prefered 1/2" thick x 5/8" wide but the 3/8 x 1/2 I had seemed to do the trick.
"New age" weatherstrip removed and open cell installed, ready to hopefully put the windows in.
I've had the windows in and out more times than my favourite hobby by this point. Still can't get the rear end to come in against the quarter panel so I'll do the other side and see what happens there.
Upper seal lip sits inside on it's own most of the way and the rear is sitting out. I presume, as the FSM detail pictures suck, that it's supposed to be tucked up inside.
All tucked in pretty...
Drivers side window went in fairly nice. The lower seal is not quite touching the quarter panel, but I'm thinking they probably never did and just leaked into the quarter panel like window whiskers would have with roll downs. That said I am going to take some 1/8" or so cord material and jam it up under the the seal into the V between the frame and flap, which should force the seal out tight to the quarter panel.
Finally some glass in the sides...
Mind boggling why the trim polishing place took it upon themselves to remove the joggle in the roof rail trim (pass side only), cracked it and welded it straight. Part of the reason my passenger window won't sit out against the quarter panel.
So I put the joggle back!
Now the roof rail trim can come out to where I think it belongs and hopefully the window assembly agrees. Saving that swearing for tomorrow..
View attachment 743357 View attachment 743358 View attachment 743359 View attachment 743360 View attachment 743361 View attachment 743362 View attachment 743363 View attachment 743364 View attachment 743365 View attachment 743366
Thanks Richard... just confirmation of which way is correct as per the above two pictures. Seal flipped out onto the top of the quarter panel, or inside against the back side of same.Wayne, what pictures would you need as above to document the seal? I can snap a picture of a 68 Road Runner that has never been apart. Very good details on the quarter window installation. Keep up the good work. It is progressing nicely.
